Bass rumble from speakers
PSchiefelbein
Pete
Mapleton ND
2018 Ford F150
Every once in a while when I start my '23 XLT hybrid I get a low rumble from the speakers instead of music. It persists while driving, even if I turn the audio and/or the truck off and on. Then, when I go to drive it later, everything is fine. Curiously, if I use my phone the car audio works perfectly, then goes back to the rumble. I tried taking it in, but they said I'd have to bring it back when it was doing it. Has anyone else experienced this or stumbled on a solution?
CurtisB
2023 Maverick XLT Hybrid
Need more details. Do you have the Bose system upgrade system or the lower stock system?
CurtisB
Cool. I have read in here that it is a software thing regarding your head unit. Some have rebooted the head unit and it has solved the problem. I don't remember the process, but I think if you type in the search bar, "reboot stock head unit", you may find an answer. Hopefully this gets you in the right direction.
PSchiefelbein
Pete
Mapleton ND
2018 Ford F150
Thank you! I'll give it a try.
