Lane
Lane
Central Wisconsin
photos.app.goo.gl
I'm going to do writeup on the main board specifically about rerouting the harness if going lower than Eibachs. It will help exactly two people and piss off 200.
You've helped another person, thank you. I left my HAG module in its original location - I didn't move it inside the engine compartment as you suggested, I just rerouted the harness to it. Why'd you choose to move the whole module? It looks to be tucked so far up in the fender that it didn't seem like it would be at risk from tire rubbing.
daddio211
daddio211
Eric
St. George, Utah
Hot rods
Happy to help. I relocated the HAG basically because one of the mounts broke due to my tire touching it on a few big bumps. Your mileage may vary, but keep an eye on it.
DuckDuck
Gilbert az
23 lariat awd
I keep looking around, seems as if those of you with standard silvers get the rear lower than mine. im as far down in back as i can be.
I can fit 3 fingers between fender/tire.
Barely 2 up front
Ford Maverick Slammed on Silver's Coilovers (23 Hybrid Lariat) 55E90358-8928-45F4-9467-D115FA7949B7
Johnny0625
Holly Springs, Ga
22 Maverick
Barely 2 up front
Mines the same too, could only get rear 3/4" lower than the eibach springs I had on before. Im out of adjustment and preload in the rear, plenty in the front though. Are you AWD? I figured that was the difference on mine.
I did go back after I adjusted them and Loosen every rear suspension bolt and retighten with suspension loaded, it helped minutely
DuckDuck
Gilbert az
23 lariat awd
yes awd as well. and I did the same right before this pic. I still love it though
Lane
Lane
Central Wisconsin
photos.app.goo.gl
Yes. Disconnect lower shock bolt. Adjust the spring to ride height then lower or raise the shock using the collars till it lines back up to reinstall the bolt. Once installed , turn the collars five rounds up to load the spring.
@Big Smitty, I just want to be clear - for the rear, turn which collars to load up the spring? The collars on the shock body, or the collars on the spring perch piece (not sure what it's called) which are in contact with the spring? From another post, I'd epxect it's the shock body, but I want to be sure.
Also for the rear, the threaded adjuster with collars which is in contact with the spring, is that adjuster installed below the spring or above it?
Sorry to invade your thread @daddio211 with these questions. I want to make sure I have the details right before starting the install. Would have been nice for Silver's to maybe include a hints/tips sheet or something.
Big Smitty
Smitty
Macon Georgia
2022 Ford Maverick XL
The threaded part with the spring is where you adjust to get your ride high. Make surly the bolt is out of the bottom of the shock, once you have your ride high set loosen or tighten the collar on the shock till it lines back up so you can install bolt back in freely. Once installed then turn the collar on shock body 4-5 complete turns to add load to the spring.
daddio211
daddio211
Eric
St. George, Utah
Hot rods
Sorry to invade your thread [USER=1855]@daddio211
No worries at all, this is all about educating each other! :)
@Big Smitty - The instructions you gave make sense for the front, but not the rear. Am I still misunderstanding? I still haven't adjusted mine.
daddio211
daddio211
Eric
St. George, Utah
Hot rods
Barely 2 up front
I'm definitely FWD, the AWD don't seem to get quite as low.
Johnny0625
Holly Springs, Ga
22 Maverick
How i did my rears, After you set ride height via the adjustable spring perch, you jack it up so suspension is hanging and screw the shock into the upper tube to preload spring.
Silvers yt video said compress it 1/4 inch. Did mine that much and rode kinda harsh, lessened to more like 1/8" and felt good.
Big Smitty
Smitty
Macon Georgia
Yes you’re misunderstanding
Call me tomorrow I’ll tell you the proper way
4788089444
daddio211
daddio211
Eric
St. George, Utah
Hot rods
4788089444
I'll call Sunday afternoon if that's okay. Sorry, been swamped with work, hunting, and planning a wedding.
daddio211
daddio211
Eric
St. George, Utah
Hot rods
Worthless little Mavericks can't haul anything, right? They're not even real trucks. And then I go and lower one and take it 65 miles on dirt roads HUNTING FOR ELK!? Yep, that's me.
Ford Maverick Slammed on Silver's Coilovers (23 Hybrid Lariat) 20231011_192005
Well, technically that's my buddy Neil scanning the hillside for elk. Forget whitewalls, dirtwalls are all the rage.
And what can a Maverick haul? How about an old 6X6 warrior?
I'm not a trophy hunter, I hunt for meat for my family. This bull will provide about 350 pounds of healthy, clean protein. 🙏😊
Ford Maverick Slammed on Silver's Coilovers (23 Hybrid Lariat) 20231014_123044
I'm exhausted and taking a nap now.
Take your lowered truck off roading (gently) and feed your family. That's the order for today.
