Side Mirror Replacement
nunucello
Marcello
New York
nunucello
nunucello
Marcello
New York
I scratched the side mirror when removing adhesive which held blind spot mirror.
The side view mirror glass is not the same as a windshield or window.
It is very sensitive and does scratch.
Capitan
Leo
New Jersey
'26 XL Hybrid AWD
I would pop the mirror off on the original to see if it matches the eBay pictures.
I have a 2026 XL with BLIS and I had to replace the entire driver side assembly.
Here is a picture of what mine looks like.
Ford Maverick Side Mirror Replacement PXL_20260813_143837475
nunucello
nunucello
Marcello
New York
That is great info. Thanks so much.
tpollauf
Toledo/Port Clinton, Ohio
1992 F-150, 2009 Pontiac Vibe GT, 2026 Maverick Lariat Hybrid
How difficult was it to remove the existing mirror (glass only) from the assembly? Did you crack the glass in the process? Was it already cracked thus why you had to remove it?
A long shot & may perform a mod in the distant future. Would like to add turn signal indicators to out Maverick mirrors and would need to remove the glass to perform the work. Thanks!
Capitan
Leo
New Jersey
'26 XL Hybrid AWD
It took some force to get it out.
The mirror remained intact.
During the process it didn't feel like it was going to break.
I adjusted the mirror all the way to one side and then I reached in and pulled the mirror.
Take a look at the tabs I circled in the photo.
That's where the mirror is attached.
Ford Maverick Side Mirror Replacement 1704
Ford Maverick Side Mirror Replacement 1705
Ford Maverick Side Mirror Replacement 1690
tpollauf
Thanks for the clarification. If I do anything like planned, I'll make it sooner than later while the plastic is still fairly pliable. Years from now it will only become brittle and subject to cracking.
Is there any reason you prefer going through the work of putting it in the mirror housing, instead of the side vent area?
Ford Maverick Side Mirror Replacement 20260814_094531
tpollauf
Yes. Having LED indication, turn signal, etc. in the mirror housing facing the rear, will allow vehicles behind you to see better if you're turning. The fender mod is awesome (plan on doing that also) but is limited to only being viewed from the side of the vehicle, not from behind it.
