I do like the look.![]()
I install mine using this video.
Works Great
I made my own.
https://www.mavericktruckclub.com/f...ult-video-night-video-added.27369/post-716449
Works Great
I had asked what video? Well I did see this and I told Fred I thought it was the best video I had seen. When I finally got my fender lights and installed them, the right side didn’t work for me either even with the different wire connection.Actually, that’s a video I used. I went back in and he had a footnote that saying that it was probably a different wire that could be used purple on green for those. I had the lights stay on, I tried that and it still didn’t work.
your right on the side marker lights . The are quite a few of them out there, with the passenger side wiring being messed up.Mabett has been a big friend of mine during my build. I have their mudflats, seat covers, side marker lights, and a couple of cab accessaries. Haven’t seen many people with the side marker lights but I assume the wiring for them is incorrect.
You're right, both sides should match.installed the mabett side lights ,passenger side had a lot of condensation and filled with water.send back and replaced the passenger side is doing the same thing???
I am having the same problem. The left side turn signal works as intended as does the right turn signal The way I currently have wired the right side light, the light continually stays lit. Also seems that this wire is always hotJust installed mine on my 2024 lariat and the right light stays on after the turn signal is shut off I did switch the wires on the headlights side to the 2 bigger wires and that did not change it. The light will turn off after several minutes. The left side works like it should. Come on mabett chime in i have the red wire unplugged for now. The pisser part about mabett is they have no contact information on amazon or a web page to send email.
I assume I wired the right side wrong. I connected the wire to a large gray wire. Can someone who has had a similar problem tell me which color wire to be connected to the marker light?
