SERVICE REQUIRED.
Hot pepper
George
Maverick XLT FX4 AWD
My XLT Eco F4X says: SERCICE REQUIRED! The point being, she has only 179 miles on it!!! I'll take her to the dealer tomorrow.
Anyone else had this problem?
Rob Cactus Gray
Robert
Sierra Vista AZ
11 Prius
Any more information to go on? Is the truck doing anything wrong? Check engine light? App provide more details? There have been a few reports of the AWD needing service here, bad PTU.
above the service required, does it say a fault?
Ford Maverick SERVICE REQUIRED. D0C2E621-0FA1-48FE-8E18-611C2771BDFF
SkeeterB
The Woodlands, TX
Mine did that on the way to dinner. After dinner there was no fault. Hasn't come back in three months. Don't forget the first 1,000 miles or so your are to expect random stuff to show up. Hope it clears for you before you have to take it in.
YOBY
Yoby
Pa
2016 RAV 4 / 2022 Maverick Lariat
Wow, at 179 mile I guess some weird things can happen. Now, if that were 1,179 miles on vacation with the family at night, that display would have been a crap my pants moment.
Hot pepper
George
I took it in and the Service Adviser said he didn't know what to do since when I brought it in, it didn't say: "Service Required"...he then took it to a mechanic to have it "reset" whatever that means. He said next time it happens to bring it in immediately. Interesting, so if I am 20 miles away from the dealer I should bring it in...I hope it won't happen again. Other than that no other problems. Though the dealer I ordered it from had 4 Mavericks, two were Hybrids. One guy ordered it and he hoped he could afford to by it, his next step was the Finance Manager. His Car was black with steely wheels. Another guy, bought an Alto Blue Hybrid, fairly well loaded with 18" wheels, it was used. There was also a Hot Redd Pepper XLT. A couple of days ago they sold a White Hybrid. Never seen that many Mavericks at a dealer. So far, the only Mav I saw on the road was an Iconic colored one; looked great.
06Warrior
Person
19' HD Road Glide, 22’ Sporster S
Before the mechanic reset it what did the code say?
06Warrior
Person
If the message said service required it must of set off a code. The mechanic plugs in a diagnostic tool into the Ob2 port and can read the code then look up what that code was. Maybe it is just a glitch and he reset it.
Decayed
yes
a car
Get an obd scanner from amazon or walmart. They cost about $20 for a basic model. It will read the codes which you can look up. The codes give fairly specific information. If no code was recorded and the message is gone, do what the mechanic says to do which is to watch to see if it comes back.
On a tangential note, EVERYONE should own at least a basic OBD scanner. If an error message pops up or your check engine light comes on, read (but don't clear) the codes, write them down, look them up then ask your mechanic. NEVER clear the codes unless you are absolutely sure the problem is fixed. Leave them for the mechanic to see.
SkeeterB
The Woodlands, TX
Don't think it will repeat. One of those glitches. Stuff randomly pops up for a while then things settle out. I wouldn't worry.
Hot pepper
George
I do not know if there was a code, if so, I was not informed of it. The mechanic had the truck for about 4 or 5 minutes. It's possible that it was a glitch. If it happens again I will let you know.
Haha48
Scott
Canada bc
I did 615km remote start sputter remote start sputter 3 times. Key start it and it threw engine/awd service required reduce power. Even sent it to the ford app called the dealer booked an appointment the wrench went away and they said it was nothing unable to replicate. It was running fine so who knows. I also had the dash screen and lights flicker up and down it was after it sat in the rain. Went away when I blasted the heat for a while. I also have a squeeky front window now as well kind of annoying.
bgn
WA
Is it squeaking and popping? That's a well known issue. I have it as well.
