Status
Not open for further replies.
fossil
ernie
ohio
True dat- It's a puzzle that you need all the pieces to but that CAI is drop dead sexy :)
Absolutely gorgeous, much better than the CAI I made for my 95 Cobra Mustang though I didn't use any duct tape or bailing wire.
It was the last piece added after - big valve Trick Flow heads, larger throttle body, polished intake, equal length ceramic headers, oversized Magna Flow X pipe exhaust system with high flow cats. That's just the air plumbing, I went a little nuts on that car. :LOL:
Nw_adventure
Salt Lake city
Yall want to see my custom DSM- 99 GSX intake :)
z28th1s
Greg
Lynchburg, VA
'25 Maverick XLT, '71 Mercury Comet GT, '71 Mercury Cougar, '69 Mercury Cougar
Really nice looking kit!
Waiting to see more details, like will it be compatible with my Cobb AccessPort 93 octane tune?
Brian_J
Akron, Ohio
'22 HPR Maverick AWD 4K LUX
@Fast Mavericks what is the maintenance on the dry filter? do you simply replace it every 20,000 mi? if so, what's the replacement filter cost? is it a proprietary filter?
Azmig88
Ted
2022 Ford Maverick 2.0 Lariat
How much does the unit *weigh?
How does that *weight compare to the stock intake?
Is the color applied or does it go all the way through?
If it’s applied, what type of coating do you use?
Is it baked on?
If so, at what temperature (Fahrenheit and Celsius) and for how long?
What is the proper **torque for the connecting clamps?
* In grams AND ounces please
** Do you recommend a ratchet and socket?
If so, what size drive would be best? 1/4, 1/2, 3/4? And the sockets: Shallow, deep or both?
I have several minutiae questions I am gathering now to ask soon
RyanB86
Ryan
MA
'23 XLT Lux EB FX4 4K (3/6/23 Prod Wk)
Are there any rain diverters or dam? What is the design to mitigate water entry and filter soak? Looks like rain water will get sent directly to filter element at highway speeds? Any info is appreciated.
Azmig88
Ted
A sincere question:
Doesn’t the stock unit have a somewhat similar diverter/dam?
I truly don’t know
rlhdweman
Random Lake Wisconsin
Yes that's what I mentioned - Flow numbers with that new inlet would be interesting -
I do know from testing at the track that removing just the stock 'elbow' there is restriction there & this new air intake looks like the best design I have seen so far. A back to back test with stock & this intake would be something I would like to see done.
Nw_adventure
Salt Lake city
Good to know- I just need to see an increase of 18hp to the midrange, 6 HP to peak on a dyno and I am ready to buy :) Looks legit, hopefully a little more intake noise without being obnoxious-
LSchicago
Lloyd
IL
That's a long straw to suck air through.
rlhdweman
Azmig88
Ted
Shorter than the stock one & much larger in diameter too.
“Shorter”
Does that mean it doesn’t go as low to the ground?
Further from rain splashing?
rlhdweman
“Shorter”
Neither intake goes anywhere near the ground, the inlets are above the radiator & behind the hood/grill, so water should not be a problem unless you drive into a lake.
Azmig88
Ted
Thank you
Status
