Roof crossbars compatible with Elevate bed rack
Cruzer
Adrian
Santa Cruz, CA
2024 Maverick Lariat Hybrid
Ford Maverick Roof crossbars compatible with Elevate bed rack IMG_4323
This is a great example of a situation where having crossbars on the cab would help keep longer loads from banging the roof . Can anyone recommend a set of roof crossbars to use with a bed rack? I am looking for something that is easy to put on and take off.
This is my first load on the rack and post! - 24 Maverick Lariat Hybrid Fwd with BAK Revolver tonneau cover with t-track and Truxedo Elevate Bed Rack
StevePlusPlus
Storb
NY
25 Hybrid AWD 4Ktow
I have the same bed rack as you and made a post about using it with a roof rack (I had a lot of details so I figured it warranted it's own thread).
I know you were asking for something easy to take on an off, and I'll say the Yakima roof rack is easy to take off, but a bit harder to put on. You're supposed to place its feet on certain spots which can be a hassle to measure, but if you put some sort of mark (maybe a small piece of vinyl or permanent marker?) to let you know where to place things it probably wouldn't be too bad. Then you use a special hex wrench to get things in position and tighten them down.
Cruzer
Cruzer
Adrian
Santa Cruz, CA
Thanks for the reply. I will check out your thread. Yakima makes good equipment and I am sure I could come up with an easy way to mark the location. Both your suggestions would work.
