Doesn’t look like water to me, more like debris of some kind.The water in the bed, is that from the cover leaking?
is the retrax box much lager ?Interesting, it looks like a much smaller package than the retrax that I installed on my maverick.
I wonder if the owner has any leak issues.
I have a tiny bit of leaking from the drain hoses in the box (probably just a little adjustment needed).
And I have found that the tailgate sides are extremely leaky.
For anyone looking for a dry bed I highly suggest getting a seal around those areas. Water coming in from the top needs to be directed backwards and water coming in from the sides can be sealed out using a rubber gasket.
Just going by pictures alone I think the retrax looks much larger.is the retrax box much lager ?
GO get a Gator soft foldable for about $270, you will laugh all the way to the bank, and it will be one of the best purchase you ever made. I promise you wont regret it.Anybody have any experience with the Soft folding types? The cheapos? I don't carry expensive stuff and don't like the idea of losing any more bed size or having it block my window if I have it folded.
Except it will be a soft cover. Not as secure, can't put things on top. Sure, soft covers might work for some but not for many of us.GO get a Gator soft foldable for about $270, you will laugh all the way to the bank, and it will be one of the best purchase you ever made. I promise you wont regret it.
A blue plastic tarp and a couple of bungee cords would work and be cheaper still,I’ve had the cheap MaxMate tonneau covers from Amazon on two trucks now and they get the job done for less than $200. They stretch a fair amount in the first few weeks and you have to adjust the tension, but those soft roll up tops are super simple. Good bang for the buck.
Ah a fellow KerbalYes, a bit pricey, but there is more assurance against random improvisational theft of bed contents with a metal cover.
I too am considering one, eventually. This model appears to take up far less space in the bed take up box compared to other manufacturers.
A blue plastic tarp and a couple of bungee cords would work and be cheaper still,but I want something more secure and elegant and expect to pay more for it.
It will be just as secure, a serrated pocket knife will go through the hard ones just as easily trust me (most are just foam inside of thin plastic veneer, some have thin aluminum)Except it will be a soft cover. Not as secure, can't put things on top. Sure, soft covers might work for some but not for many of us.
