Right Rear window stuck down? Quick Fix!
Cactuspicious
Epi
Chicagoish
2023 XL AWD, 1967 Mustang
I would like to address this growing problem with a quick emergency fix to get your window up!
This specific fix is for the RIGHT REAR window that will not go up. This applies to the XL and XLT models without auto down/up feature on the passenger windows (This will work for auto down on the driver's window only). Please read this entire post carefully before proceeding. I am trying to provide a service for those who have this issue and can't get to the dealer right away, i will not be liable for any damages that may occur. Use common sense and please follow the directions.
A bit about me : I am an ASE certified tech with 20 years experience. I own a '23 Maverick XL with 7K miles and this recently happened to me.
Problem: You roll your right rear window down and it either: went down all the way on it's own after touching the button OR you rolled it down and now won't go back up, particularly from the driver's switch.
From everything that I've read lately, the common problem is in the driver's window switch.
If you have an XL or XLT WITHOUT auto up/down feature on your PASSENGER windows-
Solution: jump the wires at the passenger rear switch.
You will need a plastic pry tool, and two 3" jumper wires (preferably 14 gauge)
First remove the RIGHT REAR window switch - you will need a plastic pry tool. I don't recommend any metal tools as it will indent the plastic however in a pinch it works as long as you're careful. Find the seam of the switch assembly that faces the rear of the vehicle
Ford Maverick Right Rear window stuck down? Quick Fix! 20230727_182000a
lift the back end up then slide rearward. The clip is very snug so it may take a bit of effort
notice the blue clip and black tongue to get an idea how it's held down (left side pictured)
Ford Maverick Right Rear window stuck down? Quick Fix! 20230727_182117
unplug the green connector by pressing the tab with your thumb then pull outward
Ford Maverick Right Rear window stuck down? Quick Fix! 20230727_182057
PLEASE READ THIS NEXT STEP CAREFULLY!!
Count the number of wires at the connector! if its 8, then proceed to the next step, if there are only 4, skip over to the auto down section.
MAKE SURE THE IGNITION KEY IS IN THE OFF POSITION! DO NOT DISCONNECT THE BATTERY!
Identify the LARGER 4 wires. They will be in a row and in the following colors:
Yellow/Orange = 12v key on battery
Violet/White = window motor (positive up, negative down)
Gray = window motor (negative up, positive down)
Black/white = ground/negative
Those four wires are significantly larger than the other four. DO NOT use the smaller four wires. These colors only apply to the RIGHT REAR window.
Jump the Yellow/Orange to the Violet/white, and jump the Gray to the Black/White
Use the terminal side, I found it's easiest that way.
I do not recommend paper clips but if you are in a pinch, make sure they do NOT touch
Ford Maverick Right Rear window stuck down? Quick Fix! 20230710_125933
Once you have made the connection, go to the driver's seat, LEAVE THE DRIVER DOOR OPEN, then turn forward the key (do not start), the window should go up. Once it's fully up, shut the vehicle down.
Undo the wires. DO NOT plug in your window switch, leave it off OR reinstall it WITHOUT plugging it in. DONE!
In the event that this procedure did NOT work, check power with a test light at the yellow/orange wire with the ignition key ON. If no power is present with the key on, further diagnosis will be necessary that I will not cover on this post.
AUTO DOWN/UP GUYS!
Unfortunately after testing the "quick fix" which was disconnecting the master switch, it appears that it will not work. The auto down/up system uses two door modules that are all interconnected through data lines, versus the auto down driver only system which is more like an older vehicle and is directly wired to the window motors. These modules are what control the operation of the windows and this was done to prevent "crushing" with the auto up function. I will look into another way around this.
I will update this once I figure out a solution for you guys.
If you want to roll the dice and replace the master switch if your Mav is out of warranty, i will leave the instructions up on how to remove the master switch.
Make sure ignition switch is OFF
Pry up and remove the Driver's window switch by inserting the pry tool at the seam facing rearward
it will take some effort as the clips are tight. Lift the backside then slide rearward.
Ford Maverick Right Rear window stuck down? Quick Fix! 20230727_181913
Once removed, unplug the main connectors and remove the switch.
the switch may not come with a bezel, there are small tabs along the body of the switch panel itself you will need to pry to get the switch out of the bezel.
Please comment with your model and window type (Auto down driver's only OR Auto down/up all windows) if this issue has happened to you and if you had it fixed, what the ultimate solution was. I hope this all helps!!
Montana
Nice. I keep a couple spare wires for bridging stuff like this just in case (to avoid having to cut new ones).
Thanks for sharing!
Lando
This specific fix is for the RIGHT REAR window that will not go up. XL and XLT models without auto down/up feature on the passenger windows Please read this entire post carefully before proceeding. I am trying to provide a service for those who have this issue and can't get to the dealer right away, i will not be liable for any damages that may occur. Use common sense and please follow the directions.
Problem: You roll your right rear window down and it either: went down all the way OR you rolled it down and now won't go back up, particularly from the driver's switch.
If you have an XL or XLT without auto up/down feature on your PASSENGER windows:
Solution: jump the wires to the passenger rear switch.
You will need a Plastic Pry tool, and two 3" jumper wires (preferably 14 gauge)
Count the number of wires at the connector! if its 8, then proceed to the next step, if there are only four, skip over to the auto down section
AUTO DOWN GUYS!
I don't know if it's a problem on XLT/Lariat models with Auto down/up on ALL windows, but if you are experiencing the same problem, try this:
Once removed, unplug the main connectors and remove the switch. Turn your ignition on (Keyless guys, push the start button without pressing the brake pedal)
You now SHOULD be able to roll your window up from the right rear switch. I have NOT personally tested this but based on the wiring diagrams, this method should work. If this method works for you, please comment and I will update this. I will greatly appreciate it!
Thanks! This is super helpful, especially when most dealerships can't get to you for a few days! You're a life saver!
Rick Hibdon
Rick
Blissfield, MI
2023 Maverick Hybrid
AUTO DOWN GUYS!
Rick Hibdon
Rick
Blissfield, MI
Can't thank you enough for this! Happened to me last night. I ended up taping over the opening because they were calling for rain. Then later, I searched online and found your post. I just got back in from following your instructions and it worked perfectly. I'd emailed my service manager late last night and he actually CALLED me a few minutes ago. Said this was the first Mav he'd heard about, but they done a number of Explorers and F-150s with the same problem. He actually offered to pull one from a new vehicle for me! And was going to guide me through the same process to get it up.
I told him go ahead and order one and call me. He agreed, got my mileage, and wrote up an invoice. Doesn't get any better than that, eh? Bell Ford. Adrian, Michigan.
PS. I bought it in Jan for less than MSRP. GOOD FOLKS!
Cactuspicious
Cactuspicious
Epi
Chicagoish
So glad to hear it worked for you! Does yours have the auto up/down on the passenger windows or the standard version with auto down on the driver's window only?
Bigbill27
Kentucky
2012 focus, 2023 Maverick Hybrid
Happened to me last month just as I was driving near my dealer after work. I stopped in and they had me on my way in about 30 minutes. Good service at Hunt Ford in Franklin KY.
Montana
Auto down driver only. I'm a cheapskate. Only ONE option (hitch)
I actually had no idea they all had auto down on my Maverick until the first time I rolled the windows down. My previous Escape only had the drivers side auto down, but it had the newer sync module... and it was the same model year but produced earlier in the year... grr. Can't have two cool things at once - that is waaaay too luxurious :rolleyes:
ssavon66
Harrisburg, PA
2012 Chevy Cruze
I came across this issue in my '22 XLT today. I have the auto down and removing the driver side switch would not work. With it removed the rear window switch wouldn't make the clicking noise it was typically making. Scheduled to go to the service department on Thursday.
Cactuspicious
Cactuspicious
Epi
Chicagoish
I really appreciate the feedback. I will try and come up with another way around this for auto down/up guys. Without one here in front of me it will be difficult to test this.
ssavon66
Harrisburg, PA
2012 Chevy Cruze
You bet. Thanks for putting this out there though. Was really hoping to just get the window up and not have to worry about taping plastic to it for two days lol.
Earlehd
Earle
Georgia
2022 XLT eco, FX4
Mine stuck down today, I used the jumper wire method above. Worked great... does anyone have a part number for xlt without auto down?
Earlehd
Earle
Georgia
2022 XLT eco, FX4
AUTO DOWN/UP GUYS!
Fixed mine today, xlt auto down driver's only
februaryfour
Ai
Aurora, CO
2023 Ford Maverick XL
Thank you for posting this. My dealership can't get a part until September 12 at the earliest, and they've had my truck a couple of weeks already. I am taking my truck back today and hopefully will be able to use this to roll the window up until they get the part in!
