- First Name
- Andy
- Jan 20, 2022
- Ontario, Canada
- '24 Corolla hatch, '25 Mazda 3
- Engine
- 2.5L Hybrid
If it reads less than what your 12v battery shows across its terminals then the most likely culprit is the crimped/soldered connection on the end of the positive battery cable under the cover. It would probable be a good idea to give that connection a wiggle while checking the voltage to see if it changes. Checking that connection (since it is a known issue) could point to it being the problem rather than a module.Yes that cable that is bolted down under. That black cover looks in good shape. If it reads 0 volts what would you suggest
Cheers.
