****REGARDING DEAD HYBRID MAVERICKS ISSUE****
Milous
WA State
2022 XLT Alto Blu, LUX, Sunroof, delivered 3/18/22
I would like to be able to find the part number for the cable, anyone here from Ford parts that could look it up?
Ford Maverick ****REGARDING DEAD HYBRID MAVERICKS ISSUE**** Maverick_terminal
The closest that I could find is #7 on the diagram below, and I am not sure if it is indeed the cable in question.
#7 is part # NZ6Z14305B, described as "2.5L HARNESS, WIRING ASSEMBLY - ALTERNATOR"... BUT, the Hybrid does not have an alternator...
Ford Maverick ****REGARDING DEAD HYBRID MAVERICKS ISSUE**** Maverick_harness_NZ6Z14305B
Mach 1
Randy
Spicewood
2022 Maverick Lariat Hybrid sold 2024 mav hybrid 2018 F150 Lariat 3.5 ECO
Good thread...the way to tell if you have the defect would be to put DVM on battery cable at junction block on vdc scale, wiggle cable/connection under hood and watch for voltage drop at battery cable junction block.
I still think i am going to dismantle, and inspect/ohm connections.
YOBY
Yoby
Pa
2016 RAV 4 / 2022 Maverick Lariat
That was my thought. When Ford decided to go for a sub 20k hybrid, with high mileage, they started cutting cost and weight. Aluminum cable and recycled plastic, what a great way to save cost and increase mileage with weight reduction. Most of us bought because it was a low cost truck with great mileage and are paying the price because the execution by Ford is less than stellar.
Error
Jeep
Here
Maverick Hybrid XLT Lux 360 Roof
ford dealerships are getting calls everyday for the maverick.. same answers.. we don't have any in stock, but we can take your name..
anyway, i plan to do some road trip in july with my hybrid xlt lux, so i bought a couple of clamps, a small iron, cutting tools, tapes, and few extra tools.. just in case. If i don't have the right tools.. ill probably use the forum to borrow some tools.. so i won't have to leave it to some random dealer 2000 miles away from my house.
pigsareus
Farmington Hills, Michigan
Maverick XL Hybrid
It's sad when you have to even consider doing that - that's the kind of cr-- you do when you're taking your old 20 years old beater on a long trip, filling up the tool box with all kinds of 'what if' paraphenalia.....not when you just bought a brand new ride, that's what a lot of us are trying to get away from...
93nighthawk
Eric
South Dakota
It would be #4 on your pic
Ford Maverick ****REGARDING DEAD HYBRID MAVERICKS ISSUE**** 1655562518061
LX6Z14290PA would be the part number for it, and of coarse it is on back order.
Scupking
2025 Ford Maverick XLT Hybrid
No thanks.... That's not why you buy a new vehicle. You expect a new vehicle to be reliable... That's a big reason you buy a new vehicle.. I don't have to take anything with me in my current 15 year old suv...
MAVRICK
Any
2024 XL
Could you also provide the same kind of exploded view diagram for Ford P/N: LX6Z10C679B? ... I'm just curious to see what the diferences are between "LX6Z14290PA" & "LX6Z10C679B" ... thanks.
93nighthawk
Eric
South Dakota
LX6Z-10C679-B is just on the battery and is your grounding cable.
Ford Maverick ****REGARDING DEAD HYBRID MAVERICKS ISSUE**** 1655564741686
rmay635703
Ryan
WisConSin
Subaru 360, Comutacar, Honda Insight, Dodge Ram
If your truck gets this problem report it to the national highway administration like any other safety issue.
Enough complaints now and then if the issue translates from dead battery to fire later in life it’s more likely to get addressed and a recall
Sadly these issues take years before they get a recall and get none at all if you don’t lodge complaints
Ford hasenough flaming F150s that a harness concern should drive more scrutiny
Hope Ford turns this into a recall or fix when I take mine in for service.
A recall can really only come from the government and Ford doesn’t want one, if they have a campaign instead of a recall they can selectively charge customers for the problem
Milous
WA State
LX6Z14290PA would be the part number for it, and of course it is on back order.
Thanks for your info, very helpful. I would guess that the eventual Ford "fix" is not going to involve replacing that entire cable, looks like it would be a major undertaking to say the least. More than likely it seems that they will come up with some sort of method to repair the bad end connector.
I wonder if the "bad" end of the LX6Z14290PA cable comes apart anywhere where just the last section could be replaced - providing that Ford has updated the cable with a more secure terminal at the end.
YOBY
Yoby
Pa
Wx Man
Hendricus
Gray, Maine USA
2022 Maverick Hybrid Lariat
  • Like
Reactions: Aza
YOBY
Yoby
Pa
Thanks for the tip! Just ordered as well....what is the acceptable range we should be looking for? Below what reading would you suspect an issue is brewing?
Anything under 11.5 shows at least one bad cell if it won't go to 12.2 when engine is off, be prepared for a bad battery.
If the voltage is jumping all over the place, the cable may need replacing. Someone could wiggle the cable with the car in accessory mode while you watch the voltage.
Helpful Reference used Industry Wide.
Ford Maverick ****REGARDING DEAD HYBRID MAVERICKS ISSUE**** BATTERY-TEST-CHART
