Recommend power tool to remove plastic shield screws?
TheSEARCH
Dan
ford
Going to eventually change my oil on hybrid. i know there are many T27 torx screws on plastic cover . thinking of getting cheap power tool to remove the torx screws. How much torque in inch pounds needed. Looking right now at cheap harbor freight cordless drills. I don't want to remove all those screws by hand.
I have air compressor and m,any air tools BUT I have to pull Mav way into back to use it so wanted something eletric easy to use to remove screws.
Is a cheap harbor freight good enough. it will be its only use . Or does it need to be an impact type tool. I can break them free by hand if needed.
Any low cost recommendations.
Flub
Alberta
Ford Ranger 08
Shall I be the first to snarkily say you should use a ratchet then?
My cordless drill is too bulky and heavy with the Mav on ramps (I tried).
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
I removed and installed MINE by hand (ratchet).
A power tool might work for taking them off.
BUT!! Using that to install.... :oops:
Some of the "Clips' that the bolts, screw into, are the "Tin-metal" type. :eek:
A friend had the dealership do the oil change on his Escape and the "Kid" stripped ALL of those clips... They (dealership) did not have enough of them in stock. Friend had to go back and have the shield installed later... :mad:
Jerry
fossil
ernie
ohio
my old 3/8" Dewalt 18V battery drill with multiple impact torque settings. 3/8" ratchet to break the stubborn ones.
Gpp
Gil
Sanford nc
2022 ford maverick
I use my 1/4 inch battery powered dewalt screw driver to remove and replace my screws.but,go ahead and replace the screw clips and screws while your at it.get some extra screws also,you WILL drop one sooner or later.
TomD
Thomas
Jeep Cherokee Trailsport
So as I read this is it safe to assume that all oil changes should be done by the dealer? If they screw something up they own it?
Fcnrwy
Jerry
Wisconsin
Maverick XL Area 51
Doesn't hurt....
Jerry
Decayed
yes
a car
This is a deeper question than you may realize.
Cordless tools require a battery to work. Because the battery will always die when you really need it so you need a backup battery and of course a charger. Batteries are expensive and low quality batteries will drain faster, die sooner and generally be, well, cheap.
So if you want decent batteries it requires an investment of some money. To recoup that investment you can get other tools that take the same battery. Hence what you are really asking is what tool system should I buy? Cheap or no name tool brands won't last or offer the same variety of tools so you get shunted into looking at name brand stuff like Milwaukee or DeWalt.
Then you need to decide which battery system you want because they often offer more than one, for instance Milwaukee offers 12 v and 18 v systems which trade weight and size for power and drain time.
Personally, I went Milwaukee M12 because the cordless drill with the smaller battery is very lightweight and has all the features you could want. They have a complete line of tools including impact wrenches, etc.. Had it for over 10 years, beat the crap out of it and it's still running strong. And I can get replacement parts if something does break. (another issue with no-name tools).
The cordless drill has an adjustable collet that can be set to slip so you don't overtighten a nut or bury a drywall screw and two speeds for drilling or driving.
If you just want something quick and dirty get the walmart house brand and call it a day.
  • Like
Reactions: bgn
WhiteMaverick12
Andrew
Tennessee
2022 Maverick XL, AWD
Impact wrench.
Fibrepunk
2023 Ford Maverick XLT Hybrid
TCPTX65
2023 Maverick XL Hybrid, 2023 Buick Enclave
TheSEARCH
TheSEARCH
Dan
ford
I will check out the suggestions. thanks
