Recalls and more issues
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
Update they took a look at it. Reflashed tpms sensor issue doesn't seem to be happening.
The voltage light still comes on but still goes away will come on at stop light and as soon as rpms go up it goes away. They said they tested the battery but noted batteries is swollen which is probably from over charge but none less said they didn't cause issue of course.
The door locks are getting worse and sync is being frustrating annoying.
All other issues still persist gonna have call lovely corprate and get the run around.
I have many fords over the years but under Farley everything has become a dumpster fire.
Your battery is swollen, you're having weird battery failure symptoms and they don't have an issue with it???
You need a new dealer with a real battery tester and a mechanic who actually went to trade school.
Mark1
2024 Maverick XLT
Well looks like Ford has 2 new Safety Recalls, although not related to Mavericks. Possible Brake failure in 130,000 vehicles due to fluid leak. And a 3rd earlier one, where the vehicle can shift from, I believe Reverse to Drive.
With a '22 - did you have prior updates done way back when?
I wouldn't be shocked that the 2 modules getting an update now (BodyCM for lights, AudioCM for camera), require other modules to be at an updated level to talk correctly.
And the tech doing the updates missed a warning, missed checking them - something that is part of the procedure of updating modules.
Actually maybe they noted the warning on 1 module and got it updated, but missed another one because the job is only supposed to take so long and he's in too deep already.
Also - is your battery the FLA that is still under a recall until they have replacements, or already have an AGM?
