Rear Strut Brace?
SaintCowboy
Tyler
us
Does anyone know where the rear strut towers are located in the truck? I think they are located in the gap between the truck bed and the paneling but I am not sure because there is no information online. But I am curious because I want to look into the idea of putting a rear strut brace on. Any help or advise I don’t even know if this is possible so all is welcome.
fossil
ernie
ohio
no rear struts, shocks
Ford Maverick Rear Strut Brace? 20230909_125705
SaintCowboy
Tyler
us
Well my front strut tower brace made my awd mav feel so much better and the front feels stable and stays level in turns, but my rear flexes and I ca feel it leaning more back there. I live by closed mountain roads that nobody is ever on and my friends and I send our cars down it.
SaintCowboy
Tyler
us
Thank you, i wonder what my options are now like maybe attaching a quick release metal bar across my truck bed above the shocks to stiffen it up mounting it with like tow hitch pins so you can still use the bed???
rallyshark
Donny
GA
2023 Maverick Hybrid
As others have said, an upgraded sway bar should handle the job. There are a few makers out there, so make your choice on which you want. It will definitely help.
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
fossil
ernie
ohio
Front struts are a integral part of suspension geometry. Suspension travel arc is defined partly by their attachment points, and caster/camber. The rear arc is defined by control arms with the rear shock being just along for the ride, doing little more than dampening wheel movement. The rear shocks are as far outboard as possible, a good thing. Stiffening the upper shock attachment will do little/nothing for your intended purpose. Some tweaking is possible with rear camber bolts.
Adding an adjustable rear sway bar could help get you there but it's best to upgrade the front bar to match.
Ford Maverick Rear Strut Brace? Mav22rear sus
as you might notice from this vid rear body roll is more than front roll.
