- First Name
- John
- Oct 24, 2021
- New York,LI
- 22 FX4, 25 LARIAT HYBRID, 26 LOBO 702.
- Engine
- 2.0L EcoBoost
Air bags deploy on how fast a vehicle stops, rear end damage like that likely pushed the vehicle in forward motion, if you were parked against a brick wall or a tree or had another vehicle in front of you and your vehicle couldn't move forward when hit depending on the speed of the vehicle that hit you the bags could deploy. Many times the cost of air bags,Thanks for your responses. Those professionals didn't take a look in person only pictures since am out in rural. Yes there was a damage to the rear bumper and hitch reinforcement. No Airbags deployed. I have been reading and looking online on Ford maverick diagram, and it appears it may only be the flanges or so-called Rail end‑face where the hitch connects but may be not the entire rail frame. because it its only minor rear end, if the boron steel is this hard. It shouldn't bend, if it did, then airbags should deploy but they didnt. I am having hard time determine that, I don't want it totaled i just need to fix this and get it inspected and registered. Any thoughts would be appreciated.
sensors and control unit total a vehicle alone of course including the damaged areas.
Yes that is frame damage, there are many repair shops that don't care about insurance regulations and would repair that damage. I believe there is a rail section for that right rail but the cost of replacement would total the vehicle. The Maverick holds its value well BUT its not a expensive vehicle and salvage value would be high.
