AbnRgr
Athens, AL
Porsche 944NA, Mazda Miata, PT Cruiser Conv.
I recently added Raptor-style LEDs to the front grill of my hybrid. Total out of pocket was under $10.00. In addition to purchasing a set of ten LED marker lights from Amazon I made use of wire and connectors left over from previous projects. Power and a ground were found at a front side marker. I still need to touch up the screw heads with a dab of black paint.
Ford Maverick Raptor 3-Light LED Grill Lights installed for Under $10 tempImageyvWtFH
Ford Maverick Raptor 3-Light LED Grill Lights installed for Under $10 tempImagebGYEnm
Ford Maverick Raptor 3-Light LED Grill Lights installed for Under $10 tempImageGSqxgD
Nilight TL-14 10PCS 3.8” 6 Amber Indicator Rear Side Truck Trailer RV Cab Boat Bus Lorry LED Marker Clearance Light, 2 Years Warranty - $8.90
Ford Maverick Raptor 3-Light LED Grill Lights installed for Under $10 tempImageJLTH4G
Ford Maverick Raptor 3-Light LED Grill Lights installed for Under $10 tempImagew8eXi
AbnRgr
AbnRgr
Athens, AL
As stated, Amazon. Cut and paste the description at the bottom in Amazon and it should take you to what I used.
GPSMan
Many
O'Riley Auto Parts.
Off the shelf.
$30.
Drilled the plastic.
Wires invisible from the front and from under the hood.
Ford Maverick Raptor 3-Light LED Grill Lights installed for Under $10 C489DFED-74F0-4DBE-B0AF-310BB8E1B317
Ford Maverick Raptor 3-Light LED Grill Lights installed for Under $10 49EB017B-EC2A-4159-92E0-AD77AE1ECD0D
Ford Maverick Raptor 3-Light LED Grill Lights installed for Under $10 C377BE90-FDA6-466F-8769-0F36E67DACBB
G19Tony
Tony
Las Vegas
2025 Ford Maverick XLT, 1994 Ford F150
Well done!
93nighthawk
Eric
South Dakota
O'Riley Auto Parts.
Off the shelf.
$30.
I used the same kit
Ford Maverick Raptor 3-Light LED Grill Lights installed for Under $10 1667841761044
93nighthawk
Eric
South Dakota
honney35
Hai
Hi GPSMan, would you please show me how to do it? Thanks
E30andrew
Andrew
Lafayette, Louisiana
'23 XLT FX4 EB
O'Riley Auto Parts.
Off the shelf.
$30.
Very clean install. Looks much nicer than the commerical 'F150LEDs.com' kit that has you run the wires up over the grill. I might actually do this mod now. How hard was it to snake the wires back after drilling the grill?
Huchipapa
Houston
'01 Trooper; '04 9-3; '13 Outback; '24 Mav Lariat
O'Riley Auto Parts.
Off the shelf.
$30.
Looks great!
O'Riley Auto Parts.
Off the shelf.
$30.
Looks great!
GPSMan
Many
Easiest mod ever.
I do recommend using solder to the splice into power. The vampire clips lost connection after a week of road vibrations. I should have known better.
Solder everything. Then you know it's good.
GPSMan
Many
Ford Maverick Raptor 3-Light LED Grill Lights installed for Under $10 04AB5157-1A43-40EA-9041-3A8BD2E049A7
Nashville Swat:
(Video freeze frame. LED headlamps were wig-wag, one is not burned out.)
