Question about using a Foam Cannon to wash my new Maverick
ListedGuru
MI
Mercury
I just picked up my new Maverick AWD Hybrid on Thursday. It's a bit of a change coming from a Mustang GT but a welcome change so I'm happy. Anyway I have used a foam cannon to wash my Mustang and our other vehicles but never a truck. So to those that use a foam cannon on their Maverick I assume you foam inside the bed of the truck? Currently my truck bed is naked but I do plan to use a bed mat and later on will get it spray lined. Just kind of curious if I should foam inside the bed of the truck and then pressure rinse the foam away like you normally would on the rest of the vehicle? I don't see why not to foam inside the bed but figured I would ask anyway...
Dave O
New Smyrna Beach Florida
I use a foam cannon on all my vehicles, prior to installing retractable tonneau cover on]n my Maverick I foamed the bed and would again if it gets dirty fortunately my bed seals pretty good so it stays dry and dust free
OleFordGuy
yep, washing the inside of the bed is no difference than the rest of the truck, regardless of "naked", drop in bed liner, spray in bedliner, bed rug, bed mat, etc
ListedGuru
MI
Mercury
Thanks for the reply and to @OleFordGuy as well. May I ask what tonneau you installed? I'm looking into those as well but I really don't want to break the bank:)
Dave O
I installed the Retrax Pro Series Retractable Cover a little expensive at $2,500 but a great solution for what I was looking for and I installed it myself I also chose the T-Slot Rail version for future hauling options the cover can hold up to 500 lbs.
Ford Maverick Question about using a Foam Cannon to wash my new Maverick IMG_4700
ListedGuru
MI
Mercury
I installed the Retrax Pro Series Retractable Cover a little expensive at $2,500 but a great solution for what I was looking for and I installed it myself I also choose the T-Slot Rail version for future hauling options the cover can hold up to 500 lbs.
Wow great looking cover but way more than my frugal self wants to spend, lol. I've seen several positive comments on the Gator SFX Tri Fold Soft from Real Truck so I'm leaning towards going with it. Here's a link just in case you want to take a peek:
https://realtruck.com/p/gator-sfx-tri-fold-tonneau-cover/v/ford/maverick/2025/
Grabber Rick
Rick
Sarver Pa.
07 Focus wagon 06 Silverado 4x4
The only bad thing about a Tri-fold is there is not much space after folding it up. The bed is shallow so not much would fit under the folded part of a Tri-fold cover. The bed is small so I bought the cheapest roll-up on Amazon. That allows full use of space in the bed. I guess it depends how much you plan on putting in the bed. You would have to remove the cover for bigger taller items.
TwuckHappens
Jefe
2025 Maverick Lariat
Personally I don't think there's not a whole lot of reason to get a soft trifold over a soft rollup- a hard trifold is about $60 more than that gator brand and would at least give you some theft protection.
Tim d
Alpena
Ram
It's a truck, I've never washed inside the bed.an occasional sweep out depending on what I've hauled.
MetalsGeek
Rough
Torrance, CA 90503
Down to just the Mav
I had an '87 Mustang GT hatchback before the Maverick. 37 years of L.A. freeway stop-&-go traffic wore out my appreciation of manual transmissions as a "purist" :crackup: . I do miss the power but love getting 43+ MPG (or 50 in that heavy fwy traffic). I'm older now and drive like my avatar anyway. I just bought a 40-gal water heater and the truck brought it home nicely. I did that with the Mustang too! The only constant in life is change. Embrace it and savor la difference...
Tim d
Alpena
Ram
Curious if you had an ecoboost instead of the hybrid if it would be quicker than your stang.possibly!
Merrick
Merrick
Lewes, DE
2025 Maverick Lariat Hybrid AWD
You should have kept both. Here is my other ride.
Ford Maverick Question about using a Foam Cannon to wash my new Maverick IMG_1822
