Question about upgrading audio and adding a subwoofer.
creepshow
creepshow
DFW, TX
2024 XLT
I'm a bit confused by this sentence. The RSE-165 are a component set with an outboard crossover. Are you saying you placed the crossovers in the dash and tapped the OEM tweeter wiring to feed the crossovers, then ran new speaker wire from the crossover to the woofer and tweeter?
Definitely likely that I did this wrong. I cut the factory harness off and spliced those wires into the input on the crossover. Then I connected the tweeter to the TW output on the crossover. I didn't connect anything to the other output.
nobbyv
The NH
'24 EB Maverick XLT, '22 Porsche GT4 & Macan S
It’s not technically “wrong”, just incomplete. My understanding (and colinl or someone can correct me if I’m wrong) is that the non-B&O system uses passive crossover components at the individual drivers and not any kind of active crossovers that are built into the head unit. So the signal going to the dash tweeter is full-range (vs the rear speakers when the head unit is set to “Driver Focus” and filters the bass from those speakers). So you’re getting the correct signal going to your crossovers and tweeters. However, your woofers are now running full range because they’re not hooked up to the crossovers. This won’t damage them (if it was the opposite and you were running the tweeters full range you COULD damage them), but from a sound quality perspective isn’t ideal. But you should be able to run some new speaker wire from the “Woofer” connection on the crossover to your woofers and you’ll be good to go. Just disconnect the woofer adapters you have on the Focal woofers now and let the OEM woofer wiring sit in the doors unconnected to anything (may want to zip tie it or something to keep it from rattling).
colinl
Colin
ICT
Hmm, I am actually not sure what this would do because another MTC member took apart the Focal RSE-165 crossover and said the woofer (actually midrange, but it's fine) connection was straight through: https://www.mavericktruckclub.com/forum/threads/full-audio-upgrade-complete.21927/post-734301
I am not sure how that would work given that the mid and the tweeter are both 4 ohm nominal. You can definitely put a filter only on the tweeter; that's a bass blocker, and there are a lot of varieties of them.
But I would think that you do want both mid and tweeter connected so that the impedance seen by the audio unit is correct. Up to this point I haven't been curious enough to dig out my (unused) Focal crossovers and check it out.
Lane
Lane
Central Wisconsin
photos.app.goo.gl
2023 Area 51 Hybrid XL, 2006 VW Jetta Smyth UTE
Nothing wrong with that; I just assumed there wasn't really room in the dash for that and most people were mounting crossovers in the doors, tapping the woofer OEM wiring.
I just recently installed a component set up front and ran all new wiring for the tweeters. When tweeters are removed, you look in that hole and can't see much because it has plastic in there which obstructs your view completely through but it does allow wires or even the factory tweeter connector to be snaked through it laterally. If you view it upward from under the dash (lying on the floor), there is a TON of room under the dash on both sides. You can reach your hands all the way up to where the tweeter mounts, if I recall correctly. There is room for passive crossover mounting, or even to get arms in and pull wires through. You just can't shove the crossover through the tweeter hole from the top of the dash. :) I should have taken a photo now that I think about it, because that amount of access from the underside is nice to have.
In reading the posts above... I've added additional wiring through factory door boots before. I don't ever want to do it again and I'll do whatever I can to avoid it. It royally sucks.
