- First Name
- Cal
- Oct 13, 2021
- Ohio...but I'd rather be in Boone.
- 2025 Hybrid AWD Lariat
- Engine
- 2.5L Hybrid
Thanks ChatGPT.My A.I. says, " Full synthetic motor oil does expire, but it generally has a longer shelf life compared to conventional oil. Unopened synthetic motor oil can last about 7 to 8 years if stored properly in a cool, temperature-controlled environment out of direct sunlight and extreme temperatures. Once opened, it can start to degrade within 6 to 12 months due to exposure to air and contaminants. The main issue is the degradation of additives in the oil, which reduces its effectiveness in lubricating and protecting the engine over time. Even if unused, synthetic motor oil loses lubrication properties beyond its shelf life, typically around 5 years for unopened containers and shorter when opened. Proper storage conditions significantly impact its longevity. " Take that info as you will.
