- First Name
- Gil
- Sep 28, 2021
- Sanford nc
- 2022 ford maverick
- Engine
- 2.0L EcoBoost
Been doing my own oil changes EXACTLY like this for about 60 years.reread this if you need two but this is definitely one of the best ways to change your oil!and keep record also!Retired tech here. I've changed oil and filter on about 10,000 vehicles. First the engine should be thoroughly up to operating temperature just before doing an oil change. Vehicle on a level surface. Engine oil pan drain plug (with no stupid aftermarket adapter) should be unscrewed/pulled quickly, even if it's dropped into an oil drain pan AND burns one's fingers. The object is to get the oil out of the engine quickly, pulling all the dirt and other contaminants at once. Also let it drain until it is down to only drips.
Reinstall the engine's oil drain plug with one hand, having the proper wrench in the other hand. (Never install a drain plug just simply finger tight, expecting to return later.)
>Pulling oil out of the top of an engine would leave much of the dirt behind.<
When removing oil filter, look to make sure it's gasket has not been left behind (stuck) where it mounts to engine. Put clean oil on surface of new oil filter's gasket and screw on thoroughly, yet hand tightened only.
