bummer but not surprised! you did everything you could on a minimal budget and a lot of elbow grease.
Dueces
Dueces
I put, what I consider, a very large price tag on it. If no one wants to negotiate based on that price, I guess I'll keep it for a while, lol.
Dueces
Dueces
Yes, volvo s60r/v70r, and I believe they are the same calipers as 06-07 STI calipers.
Dueces
Dueces
Just adding a small update. A long time ago when I installed my fuel pump and adjustable fuel pressure regulator, I could never fill my tank all the way up after that. Come to find out, when installing the ring that holds the fuel basket in place, I didn't get the ring seated correctly. The weird thing about our gas tanks is that roughly 5 gallons are located above the fuel basket ring! I'm surprised they would do it this way, but long story short, I filled my tank full for the first time in roughly 2 years! Lol
Ford Maverick Project QuikRik. My Velocity Blue XL AWD Performance build 20241223_162749
kalae594
Mitch
Wailuku Maui Hi
2024 Ford Maverick XLT
Gonna start the install on the Corsair turbo, plugs and HPFP in 2 weeks. Any advice? Super excited! @Dueces
Dueces
Dueces
Just give yourself plenty of time. I think if you remove the transfer case, you will have to grind an unused threaded boss off for it to come out. I didn't remove it, but doing so saves a ton of headache and gives better access.
Is your corsair turbo upsated with a better compressor wheel?
kalae594
Mitch
Wailuku Maui Hi
No, didn’t do the stage 4 set up. Wanted to see what it does without. Not gonna go full bore. Still an everyday driver
kalae594
Mitch
Wailuku Maui Hi
@Dueces Truck is in shop as of Friday. Hopefully done today. They pulled the engine from the subframe and they were working it. Will keep you up to date soon.
kalae594
Mitch
Wailuku Maui Hi
Yes! HPFP and Corsair turbo went in. Truck ran good but with tuning, we were running outta injector so I decided to purchase the injectors from norstrum as well (should’ve done it all one time).
Now in data logging stage. Truck gets up and goes!!!!
Chris25James
NE Ohio
2024 Ford Maverick Lariat
That’s great to hear! Just to confirm, did you do the stock Corsair turbo? I have one with me that I am getting ready to do a driveway install with, but I don’t have the HPFP or injectors. I am curious, did your tuner recommend you those parts? I was thinking to get the fuel pump and injectors if I decide to send my turbo out for something like the 57mm build.
kalae594
Mitch
Wailuku Maui Hi
I followed this original post and actually piece it together.
Used a new stock Corsair turbo because I wasn’t gonna spend $4k for the CTR 57.
Injectors and HPFP just help unlock more from your engine and the turbo.
My mechanic dropped the engine completely out instead of taking out the AWD system.
WhatJoeKnow
Land O Lakes, Fl
Sorry to bring up an old post but about how many hours did it take for the shop to install the turbo? Thanks!
Taemian
BC, Canada
2022 Maverick Lariat, 2004 supercharged MercuryMarauder, 2007 Landrover LR3(x2)
I come from LandRover world, and it's usually body-off to do serious work to the engine...quicker and much easier than anything else. What's involved with Mav's engine from subframe removal? I worked on the old Taurus platform....4 bolts and the whole subframe came out with the engine like the box off a pickup truck.
Ford Maverick Project QuikRik. My Velocity Blue XL AWD Performance build lr3 body off 2
