I would be concerned about fluid volume and any effect it has such as brake proportioning.
The Car and Driver tested Volvo was on 235 sized tires. Which is similar to alot of Mavericks it is also on tires from 15 years ago. I wouldnt be so sure about them being all that better than the treads today.Brake upgrades provide benefits, but shortened stopping distance is not one of them. That comes down to tires. See this article from Road & Track magazine.
I don't think it will be very accurate to compare the Volvo's stopping distance since it's on different tires than the Mav. And if that model Volvo costs more than the Mav, it's reasonable to expect that the tires are probably better than the Mav's as well.
If you want to get the most out of your brakes, whether they're stock or upgraded, use better tires than what came on the XL from the factory. @Dueces - I hope that's a part of your plan (I haven't read your whole build thread).
Been reading through your posts. (Awesome!) I’d love to run the bigger turbo and a mild tune but my skills and mechanical patience is pretty limitedLooks great! On a different end of things I really need to make something like this out of steel. I popped the rear scoop( bumper I mean) off on one side offroading. It really not a great setup. I need to make something similar for a skid plate.
At first I was really flattered until I realized this post was meant for Dueces.Been reading through your posts. (Awesome!) I’d love to run the bigger turbo and a mild tune but my skills and mechanical patience is pretty limited. I’ll live vicariously through you.
I love your concept of better aero! I was actually thinking of using a fairly stiff plastic. The underside aero is a mess underneath these trucks. If you can get a thin aluminum or reasonably stiff plastic underneath (especially under the hot bits, aluminum) put the correct “bow” in it and you could get some downforce with little drag. But smooth is good.
Im a huge Formula One fan and love all the aerodynamics that go along with. The big problem that they face is the tires. Creates a LOT of dirty air/drag. (Maybe put larger spats in front of the tires. At least during a run. A front air dam very close to the ground will keep the air out from underneath. Also look at the leading edge of the hood and the upper grill area. Anything to smooth that area would help. Land speed cars use good old duct tape to seal up every seem, parts of the grill etc. might be worth a look to see what they do with stock vehicles. mirrors are also terrible for aerodynamics. Maybe try folding them in during a run. Just my 2 cents. Can’t wait till you’re in the 11’s! Post a you tube video of one of your runs!
