Perimeter Plus Alarm not working
Jpalmer1
Dallas, TX
2025 Lariat Hybrid AWD
I've had my 2025 Lariat Hybrid AWD about a month. The window sticker says I have the "Perimeter Alarm". However, I can't get it to work. I've read everything I can find about it, which all says it's activated by the key fob LOCK button. However, I've tried this one click, two clicks and make sure the keyfob is then very far away and not reading, then wait up to 10 minutes to be sure . . but no matter what, I cannot get the alarm to chirp or sound no matter how hard I bang on the truck. Is anyone else having the same issue?
Jpalmer1
Jpalmer1
Dallas, TX
oh wait . . is there a difference between "Perimeter Alarm" and "Perimeter Alarm Plus"? Maybe the "Plus" refers to the shock sensor and the "Perimeter Alarm" without the Plus does not have the shock sensor? . . just a guess that occurred to me.
OB1e
Massachusetts
CG LUX XLT
Could be sensitivity set way too low. The module has a dial to turn on it. Stick your head under your steering wheel column with a flash light.
Jpalmer1
Jpalmer1
Dallas, TX
I looked, but don’t see anything under there. Do I need remove covers on the 2025?
OB1e
Massachusetts
CG LUX XLT
Google is giving mixed answers. Point fob at the locked truck. Hit lock, unlock, lock..... What does it do?
BlueSpec1
Gene
mcluvin
CR-V
If you take a look at the module, I'd be interested to know the part number. The Ford website is telling me the part # that worked for the 2022 to 2024 Maverick won't work in the 2025.
Ford Maverick Perimeter Plus Alarm not working 1742933157726-n4
BlueSpec1
Gene
22-24 Ford Perimeter Plus VSS plugged into the rear of the Gateway Module/Data Link.
2025 Maverick labels one Module 15604 in bottom parts pict as Alarm/Keyless Lock System Kit
That doesn't quite sound like Perimeter Alarm, more like the BCM module.
Part#: RU5Z15604Z
Usages: Body Control Module (BCM), 11/11/2024, Maverick 2022-, Keyless Entry/Start - Passive, With Remote Starter
Description
• Body Control Module (BCM). Keyless Entry / Start Passive.
• With Remote Starter.
Part#: RU5Z15604Y
Usages: Body Control Module (BCM), 02/03/2025, Maverick 2022-, Keyless Entry/Start - Passive, With Remote Starter
Description
Ford Maverick Perimeter Plus Alarm not working 1742987758758-j2
Seems to be quite a difference between Gateway Modules for 2022--2024 Maverick and 2025 Maverick.
Gateway Module - 2022 to 2024 Maverick
NOTE: The GWM communicates with the 5 Controller Area Networks (CANs).
The OBD DLC is fitted to the GWM and is the interface with the diagnostic scan tool.
The GWM is mounted under the driver side instrument panel.
The OBD connector is fitted to the GWM.
NZ6Z14F642A
Ford Maverick Perimeter Plus Alarm not working Gateway Module NZ6Z14F642A - 2022 to 2024 Maverick
Gateway Module - 2025 Maverick
NOTE: The GWM communicates with the 7 Controller Area Networks (CANs).
The OBD remote DLC is connected to the GWM and is the interface with the diagnostic scan tool.
For diagnostic scan tool access, a remote DLC is mounted under the driver side instrument panel with a harness connected to the GWM.
PU5Z14G490AU 11-11-2024 to 2-3-2025
PU5Z14G490AY 2-3-2025 to Present
Ford Maverick Perimeter Plus Alarm not working Gateway Module PU5Z14G490AU - 2025 Maverick
