Parking Brake, Off Road symbol, Electrical symbol - No Adaptive Cruise control
Thomas.Roane
Thomas
Virginia
2022 Ford Maverick Lariat FX4 Offroad
Something really weird is going on with my 2022 Maverick Lariat Off Road FX4 gas only truck. The parking brake light stays on. I get all kinds of messages flashing that many features are unavailable. It drives okay. But the lights won't go away and the adaptive cruise control won't work. Any ideas on what the fix may be?
Ford Maverick Parking Brake, Off Road symbol, Electrical symbol - No Adaptive Cruise control dashboard
gte105u
Katy, TX
Your vehicle is under warranty take it to the dealer.
Thomas.Roane
Thomas
Virginia
Thanks! I made an appointment. Any idea on what the problem might be?
commadorebob
It's a computer with wheels. When in doubt, reboot. Which for a vehicle involves disconnecting the battery for a bit.
Lofton
Alejandro
Central IL
Did you recently install any electronics or was this out of the blue?
Thomas.Roane
Thomas
Virginia
It was inspected Friday (3 February). All I had done was tires rotated. Worked fine Saturday. Then Sunday morning I had the problem.
I did disconnect the battery for more than an hour. Same problem occurred. It's really bizarre.
mktmgrjrm
North Central Ohio
2025 Maverick Hybrid, 2024 Escape Hybrid
I believe that the Maverick has ABS sensors in each wheel hub. The yellow warning light is an ABS fault. It's possible that the sensors were damaged when your wheels were rotated.
NoVaJimmy
KCMO
Lexus GX 460
This is why I do all of my own work, even for minor things that would otherwise be covered by warranty, you just can't trust people working on vehicles, so many hacks out there just trying to stack up their flat rate hours.....
Thomas.Roane
Thomas
Virginia
Sheesh, just discovered that my brake fluid is leaking somewhere too. Wonder what the mechanic did?!?!
Ford Motor Company
Official Ford Account
Dearborn, mi
commadorebob
Thomas.Roane
Thomas
Virginia
Just to close this out, my left front brake hose was leaking. Hall Ford replaced the hose and "missing bolts." That's disturbing. Dunno how they would go missing. The tech said the hose was a recall item. I never got notification about that but whatever. It's working fine now.
Thanks all!
