? On active shutters.
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
I had wreck and they replaced them, not sure if working. Can anyone out there show me a video off the shutters working during startup, please
Need to see if mine work
Backin15
Frozen Minnesota
2025 Maverick XLT
Stand in front of it and hit the remote start. I dont know if they only function below a certain temperature though.
Bobby Chapman
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
I would do that , but mine is a strip down xl, no remote,but I sent up camera in front and I started it cold and no action.
Maverick_Dave
KS
2025 XLT Mav. 2000 Explorer. 1986 Camry
If there is a problem with it, it should trigger a check engine light after a few times.
Bobby Chapman
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
No code, was reading that maybe autobody shop did not recalibrate it with the new shutters, or maybe a blown fuse, but cannot find which one it is, owners Manuel, no help. Google search not helpful with which fuse either.
Maverick_Dave
KS
Perhaps they left it unplugged, or there is a problem with the wiring.
Check fuse 8, under the hood.
Ford Maverick ? On active shutters. 1771802099396-s7
Ferta McDaniels
Okeana, OH
2025 Maverick XLT Hybrid, 2021 F-350 Superduty
I use Car Scanner and have a few gauges that I like to monitor. A few weeks back I added the grill shutter position gauge out of curiosity. It's winter and during the extreme cold we had recently, I did not see any opening at all of the shutters on the gauge. A few days ago the weather warmed a bit, into the 50s, and I finally saw some movement on the gauge. While driving I never saw more than 7% opened. When stopped with the ICE running or not, the gauge opened up to 67%. Probably will see more shutter activity when the weather warms up a bit.
I'm thinking I may get a monitor.....
Bobby Chapman
Bobby Chapman
Bobby
Orlando fla.
2023 maverick
What brand of scanner do you have? And monitor?
Ferta McDaniels
Okeana, OH
I use this scanner:
https://www.amazon.com/FlyroadUp-Sc...L1PL58&psc=1&ref_=pd_basp_m_rpt_ba_s_1_pr_sc#
It bluetooths to my Android phone. I use the app Car Scanner ELM ODB2. You can setup a ton of gauges using this app. I chose this scanner because of the off button. You can turn it off and on and not have to unplug it to stop the power draw. I have used other cheaper scanners with success but had to remove them to power them off. Any ELM 327 bluetooth scanner should work.
