No drill front license plate for just $20
dags1207
dags1207
Dallas, TX
2023 Ford Bronco | 2024 Ford Maverick
Any concerns about reduced airflow once the plate is put on?? Ford already removed a couple of the active shutters to increase airflow.
I don't really want to block anything but i reeaally dont want to drill the body for sure. Glad my dealer didnt. I thought it was odd when he said that but seeing how it's done yikes no.
I may just keep it in the windshield or something til I find another option
I would have done this too but didn’t want anything blocking the intercooler. Also looking into remove inch some of the active shutters.
No concerns, the shutters close and open, so if "more" air is needed, it might keep the shutters open for longer, but that's about it. Placing it in the center also uses the small shutter area that already covers the radiator, so it's a bit less than what it actually is. Also, given that is it not flushed against the intercooler, air will still make it in there.
Worst scare scenario I can add some speed holes to the license plate :ROFLMAO:
The-X
Midwest
Maverick XLT
I've seen plate holders for other vehicles that support off the bottom of something and angle up but I don't know if any work for the maverick uet. I'd rather have one that didnt interfere with any component operation (yes even a little). Diffused choked off airflow isnt the same as direct high speed flow and i don't want to find out the shutter life span.
Worst case scenario I'd have to make something myself but I'm definitely not drilling into it. It's weird thats the default option honestly. Ive seen people just leave it in the car itself like the front passenger side. That may have to do.
dags1207
dags1207
Dallas, TX
I have one like that for my wife's bronco (because the ACC sensor is down in that area). It uses two L shape brackets that sandwich the bumper inner lip (it is metal in the Bronco).
On the Maverick I was concerned with the lack of ground clearance if I did something similar, not an issue in the Bronco though
This is where part of my reasoning happened too. The non ACC equipped Broncos have that space open, but Ford covers the shutters on ACC models to add the sensor. The Bronco engine generates a ton more heat than my hybrid engine, so I assumed it will be fine. I drive too much to have "will I get pulled over" on the back of my mind :) But I understand your concerns and desires for another alternative
Active grill cost = $120
Ticket for TX front license plate violation = $200
Ford Maverick No drill front license plate for just $20 1708542911309
CurtisB
2023 Maverick XLT Hybrid
Would you be able to post a picture of how your solution looks? Sounds like an interesting compromise. I was thinking about using the "dimples" on the black plastic part of the bumper for the top of the bracket and zip tying the bottom.
See post #7, thats me
SaltyJim
South Chicago Suburbs
2024 Maverick Hot Pepper Red Lariat Lux Hybrid
Doh! Guess I missed that. Looks like a bit of air can get through under the plate. Nice! Thanks!
dags1207
dags1207
Dallas, TX
I did this on my 2015 Prius. No issues at all. If anything, the ICE warms up faster. Doing this on my Maverick, I expect the same results. It just looks better.
Nicely done! I didn't know the frame would fit upside down. But this is a great alternative as well! Still need to drill into the black part of the bumper, but better looking!
BadAl
Al
Southside Va
2023 XLT hybrid
I found a similar version on Amazon that included hardware and metal zip ties for $7.99
dags1207
dags1207
Dallas, TX
Uhm... maybe... it will be more productive to also share the link for all of us?
BadAl
Al
Southside Va
2023 XLT hybrid
Maybe you could have found it yourself quicker than writing your snarky reply?
