No Audio or Touch Response
washamur
Wade
Maverick Lariat AWD
Has anyone had this issue or currently going through this? I can tell you everything has been tried. It’s been to the dealership no less than 4 or 5 times and each time the audio stops working within a day of picking up. They have replaced modules, wiring, the whole unit, and various program updates.
I have the Lariat with the B&O upgraded sound system. There is no response from the screen when trying to get the audio to turn on. The video attached is what I sent my tech after picking up my truck this last time. I was thinking it might be a heat issue, but as you can tell it wasn’t hot at all. Any help would be greatly appreciated.
DIYDad
Jeff
Maverick on order
I know there is a way to reset the system. In the manual it says to press two buttons at the same time until it resets.
I have had to do this 3 times in the last 9 months. Audio comes right back but I notice the system in general exhibits quite a bit of lag.
washamur
washamur
Wade
Maverick Lariat AWD
Yeah, I’ve done the soft reset (power / skip forward) many many times. Also a complete hard reset through the settings and we’ve even pulled the battery cable for 15 minutes. Thanks.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hello there. I'd like to take a closer look at your Maverick's screen/audio issues. Can you please send over a private message with your VIN and the name and location of your local Ford dealer to get started?
Gullzway
OK
1968 Ford Mustang Fastback
Does it does anything different when you plug in an Android or Apple phone?
Deleted member 6544
Guest
And you folks say Ford doesn't care. Good luck OP.
NJ Pinelands
New Jersey
Chevrolet
My hybrid XL build date is September 12 so I haven’t received mine yet. Do you have to use the video screen to turn the radio on/off, change stations, and adjust volume or are there buttons you can use and just bypass the video screen. I would prefer to use the screen as little as possible.
Ford Motor Company
Dearborn, mi
Hi there. This resetting concern doesn’t sound like something we want you to experience with your Maverick. Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to look into how I can assist you on my en
washamur
washamur
Wade
Maverick Lariat AWD
Just a quick update - received a call / text from my technician letting me know they were able to duplicate the problem and get an error code. They traced it to the ACM (Audio Control Module). It being a holiday weekend, they won’t be able to see about ordering a new one till Tuesday - but at least it appears we are on our way to a fix. 🤞
