1 touch window question & Audio LOC/RCA question
GambleGarage
Paul
Chicago
22 maverick
Say I want to install a small sub. Do people still use line out converters for RCA input or should I just get an amp with high input and splice into the speaker wires? Hoping I can find a wiring diagram and get to it all from behind the back seat except the power wire. That being said are these under seat amps decent or should I look into a bass tube for under the rear set or just build the worlds smallest box for behind the rear seat? (I dont have sync3 if it matters)
I never realized how much I would miss 1 touch up/down windows for both fronts. What are the odds of a window switch off another ford can be a direct swap and work? I know autoloc makes a module but can't wrap my head around how it works if the switch doesn't physically have all the positons that a normal 1 touch up/down switch has.
