- First Name
- Jonathan
- Oct 3, 2021
- Pennsylvania
- 2022 Maverick, 2006 Mazda MX5, 1973 Super Beetle
- Engine
- 2.0L EcoBoost
Anker makes pretty good cables, I would try to find one with a fairly robust cable so it can take some abuse from moving around. I assume it is either USB-C or Micro USB. Once I got a decent one I had no issues since and keep a spare in the glove box.Didn't consider the data rate, that's a great point. Any recommendations on cable brand, etc.?
You can pick them up fairly cheap at BestBuy, amazon your store of choice. but if you are using the one that came with your device and it has a thin wire it could be a slight kink in the cable and the random disconnect could be caused by the cable having a hairline flaw in the wire and your disconnect is a bump in the road possibly. A cheap fix if that is the case.
