gsglassm
Greg
New Hampshire
2025 Oxford White LOBO, Honda Element SC
I saw these tail lights on Amazon and wanted them.
I started the install and quickly realized that I have all clear bulbs.
Swung buy the autoparts store and no one had red bulbs to fit. So I figured until I find some proper red bulbs I’m going paint some clear ones. Picked up some red caliper paint because of the heat resistance. I then Swung by my local Ford stealership and picked up 4 clear bulbs. I was shocked at the $19.95 cost per bulb!
Painted and installed them.
I think they work well for a temporary solution, but I really like these taillights.
Anyone have a link to red LED bulb?
Ford Maverick New taillights on my white LOBO IMG_2928
Ford Maverick New taillights on my white LOBO IMG_2929
Ford Maverick New taillights on my white LOBO IMG_2930
Ford Maverick New taillights on my white LOBO IMG_2931
Ford Maverick New taillights on my white LOBO IMG_2927
Cancunbadlands
Cancun
Cancun
Looking sharp 👌 😎
trashwing
Asheville, NC
2025 Maverick Lobo
Looks great! What hitch cover plate is that? All the ones I look up say they are "Not for Lobo" but that looks like just the regular Mabett one painted?
gsglassm
gsglassm
Greg
New Hampshire
That cover plate is the Mabett one painted a doesn't fit. But because I paid money to have it painted i'm using it until I cut out and paint the correct one.
trashwing
Asheville, NC
2025 Maverick Lobo
Ahh okay I was hoping there was one I hadn't seen yet. It looks like it fits okay. Does the contour of the curve just not match the bumper?
gsglassm
gsglassm
Greg
New Hampshire
Would Red LED's work?
Yes, but I originally didn't realize I need new bulbs so I didn't look into getting RED bulbs. Now I do need to see if I can find RED LED's.
If anyone knows of a company that makes RED LED's that will fit please
Chapystick
Drew
Iowa
2025 Maverick Lariat (Ordered) + Mazdaspeed6
Did your original taillights not have the LED strips that run around the perimeter?
I’m not sure which trims have those exactly
rileyfuego
Riley
Ontario, Canada
2024 Ford Maverick XL Cactus Grey
So I actually got these same ones installed on my ‘24 XL last week. Same issue as you with not having bulbs in red. Despite the part stating you can use the existing bulbs I already figured the halogen bulbs wouldn’t be the correct color.
The only place I could find LED turns / brake light was Diode Dynamics. They plug right in and work no problem. Only thing is there’s small tabs on the LED bulbs that you’ll have to cut off to fit them in the socket (as advised from the brand themselves) and you will most likely end up with the turn signal indicator on the dash hyper flashing — the lights themselves will flash normally. This you can disable through forscan.
Make sure you buy new push clips for the tail lights as well to ensure they fit with minimal gap to the body as well.
I went with the 250lumen (HP48 model) bulbs from Diode Dynamics and I feel they’re adequate but I might swap them out to the 310lumen option (HP11) for just a bit more brightness to be better safe than sorry.
They look sharp as can be on the white Lobo!
Ford Maverick New taillights on my white LOBO IMG_8486
Ford Maverick New taillights on my white LOBO IMG_8487
Ford Maverick New taillights on my white LOBO IMG_8491
Chapystick
Drew
Iowa
They did not. I have the 2025 LOBO
Is it the XLT trim lobo? I don’t remember the order code they called it, the one without the lariat driver assists and stuff?
Because I have a 25 lariat and it has the LED accented tails, otherwise I’d buy these immediately to get rid of the red.
gsglassm
gsglassm
Greg
New Hampshire
I do not think the LOBO is the XLT Trim as I think it's a different trim than the XLT.
I'd pop out your taillights (2 philips screws) and see what you have before getting a set.
I am super happy with the quality of the taillights so far.
Maverick123
Waiting
Lobo low is based on an XLT, and doesn't have LED perimeter light
Lobo high is based on a Lariat and does have the strips
The pictures of your truck look like they're in black & white 😄
Dunno which bulbs are in the lights but Walmart and AutoZone sell red LED bulbs in many different models
gsglassm
gsglassm
Greg
New Hampshire
Your Mav looks great!
I"m going to keep looking I don't want to have the Hyperblinking issue with the Diod Dynamics as it would set off my ADD :)
gsglassm
gsglassm
Greg
New Hampshire
I think I may try these Morimoto XB LED Bulds
https://www.headlightrevolution.com/4257-Morimoto-XB-LED-Bulbs-Resistor-Free?quantity=1
