Need help Ambient air sensor/pig tail question
KC.Jones
LA
XL Hybrid
Did you also do the reset procedure via Forscan? Service manual says it's required if the sensor is replaced.
How does one go about reset procedure after replacing the sensor?
bgn
WA
I believe it's available in Forscan under the service procedures.
KC.Jones
LA
XL Hybrid
Do you have access to the service manual and if you do could you be so kind as to let me know what it says about this topic? 🙏
bgn
WA
Thank you so much. I was hoping I could do the reset in FORSCAN, but clearly I can't. Thanks for your help.
You should be able to. It doesn't call out Forscan because that's unofficial software. I'll check later today when I'm driving and report back.
bgn
WA
Looks like it's possible from the android version.
Ford Maverick Need help Ambient air sensor/pig tail question Screenshot_20250620-155705
KC.Jones
LA
XL Hybrid
You're right, thanks! Just did the reset and still no dice. I'm going to try another sensor and then if that doesn't work I'm just going to have to pay the dealership to fix this. Not having AC in the summer is brutal
bgn
WA
Wiring issue maybe? Might want to pull the code if you haven't already.
rk06382
Robert
Alaska
2025 Velocity Blue Maverick Lariat Hybrid, 1990 Ford Ranger XLT SuperCab
Just do it old school & open the windows.
KC.Jones
LA
XL Hybrid
Haha that's what I've been doing for almost a year now. That WD60 (windows down, 60mph) only does so much in a LA summer
KC.Jones
LA
XL Hybrid
Thanks to the help of everyone in this thread I was finally able to fix the problem!
I bought a new sensor from that Amazon link that was provided for $10. Soldered it in place and heat shrank the wires. Started up the truck and immediately had a temperature reading on the dashboard. I let the truck run for about ten minutes and the check engine light was still on so I didn't try running the AC yet. I then used Forscan to reset the DTC's and and ever since then the check engine light's been off and my AC is pumping out ice cold air. Man what a relief! Hopefully this repair holds long term 🤞
Thanks again everyone for all your help.
DannyUncanny
Dan
Maverick XL
I’ve got the opposite problem of this thread. Bumper damage ripped out the connector so now all I have is a sensor and two torn wires. The connector vanished. Anyone have any idea what kind of connector it is?
Hot Runr Guy
West Chicago, IL
LudaFish
Chad
2025 Ford Maverick Lobo
I’m having an issue with my a/c going from cold to warm while driving. I made an appointment at the dealership for next week for a minimum of $240 they say.
I do not have a CEL and my temp on the screen reads. Is this sensor worth a shot for $10 ?
2025 Lobo
