Motrum clear markers on Amazon.
Headcase650
Adrian
Missouri
Lariat FX4
Motrum clear markers and Diod Dynamics amber LEDs. Blue painters tape, plastic panel remover tool used to install. Put two or three layers of blue painters tape at the back of the lens overlapping slightly so you can tuck it behind the lens. Wedge in the flat end of the panel removal tool at the back and work it down behind the tab, then pop it out from the back. Remove the socket from the lens, change the bulb, hit the unlock on your key fob to ensure the bulb lights up, if it doesn't remove the bulb turn it 180° and check again. Insert the socket into the new clear lens, insert into the fascia. Looks way better than OEM, ties in nicely with the Lariat headlights.
Ford Maverick Motrum clear markers on Amazon. IMG20250411180011
Ford Maverick Motrum clear markers on Amazon. IMG20250411180024
Ford Maverick Motrum clear markers on Amazon. IMG20250411180050
Redline
Upstate, NY
That looks awesome. I'd like to try that with the smoke lens. I don't have a panel remover. Are they basically all the same or is one better than another?
Headcase650
Adrian
Missouri
Lariat FX4
This is the kit I have. I've used it six or seven times. I did have to file down some rough edges around the mold marks before I use them. https://a.co/d/7BgfZKg
Redline
Upstate, NY
That's a sweet kit. Now if I only knew how to use it. :cwl: :unsure:
Redline
Upstate, NY
But there's so many... :shock:
Ford Maverick Motrum clear markers on Amazon. Screenshot_20250411-203013
Sticks
Shawn
St. Louis
Dmat
Baton Rouge
MAVERICK
bought those too. just never posted about them.
