Most negative offset wheels possible with stock suspension (XLT AWD)?
2025 Maverick XLT
Quick question, and yes i searched and couldnt find an answer. What is the most negative offset wheel i can use on stock suspension XLT AWD keep all other wheel dimensions the same?
AUsomTiger
Sweet Home Alabama
2025 60th Anniversary Mustang GT BB #0073, 2022 Maverick Lariat
Corrected my mistake.
Stock Maverick wheels tend to be around +37. My Fast Wheels FCO4 wheels are +45 and 19x8.5 inches. I think some other Fords go up to +52. I used this website to see how my new setup should compare to stock. https://tiresize.com/comparison/ You probably already know this but lowering or raising your truck can also impact fit.
Itsdavebr0
NY
2024 Maverick XL
Stock Maverick wheels tend to be around -37. My Fast Wheels FCO4 wheels are -45 and 19x8.5 inches. I think some other Fords go up to -52. I used this website to see how my new setup should compare to stock. https://tiresize.com/comparison/ You probably already know this but lowering or raising your truck can also impact fit.
Incorrect. The Maverick has a POSITIVE offset of 37.5mm
AUsomTiger
Sweet Home Alabama
2025 Maverick XLT
I plan on keeping everything stock for now, but want wheels that are slightly passed the wheel well. Cant stand how far inside the rear wheels are. I also dont want spacers either.
Itsdavebr0
NY
2024 Maverick XL
the wheels are close enough to the wheel well. Get something with the same offset but slightly wider, or something with an offset no less than +27mm
2025 Maverick XLT
What is the widest tire that can fit on stock xlt wheels
Clarkdonbran
I totally understand this thread
Ford Maverick Most negative offset wheels possible with stock suspension (XLT AWD)? IMG_4666
Clarkdonbran
I dont recommend posting selfies on forums but you do you. seriously what about this post do you not understand. Enlighten me.
It was a joke. Your thread was probably completely understandable for people that know cars. I don’t so much. You’re new here so you haven’t seen that my contributions are mostly dick and fart jokes. I hope you’ve seen Waterboy and don’t really think that is me.
2025 Maverick XLT
I kinda figured that. Thats why i replied the way i did. Yep thats me, the newbie 😁
Mox4615
Jeremy
NC
2024 Lariat
Nothing wrong with spacers, I’ve had some Bonoss spacers on the rear wheels for almost a year and never had any issue.
2025 Maverick XLT
Ive had them on other vehicles but always got nervous and constantly worried
Mox4615
Jeremy
NC
2024 Lariat
Understandable, if installed correctly I think they are perfectly fine but it sounds like youre pretty set on wider wheels and tires. I wanted to go that route but didn’t wanna spend the money so I went with spacers and stuck with the stock wheels and a wider tire
2025 Maverick XLT
What size you using in the rear? Trim or modify studs?
