Is there anyway to see the total miles driven electric versus ICE other than just at the end of each trip? The car is obviously tracking that, but I don't see any way access it.
On many of my short to mid-range trips I'm seeing as much as 75% or more of the drive is on electric only. Yes, without the ICE to get it moving to begin with there would be no regenerative power, but there is very much a difference between running in hybrid mode, battery plus gas, and running on electric alone. I'm finding that I can run on electric for a bit, let off the gas and let it regenerate, then go again without stopping or slowing much, still electric only.Kind of a dumb point for me to make, but it occurs to me that there are zero miles driven electric in a Maverick hybrid, because it is not a PHEV. There are only miles driven by gasoline. Even battery mode is indirectly gasoline, since every electron used in a Maverick hybrid is originally derived from gasoline. That includes regenerative braking, if the Maverick hybrid has that (I hope it does).
On my XL, it just shows how many miles electric and how many ICE after each trip, when I power off the vehicle. Based on a SWAG, mine is probably about 50% each, for most of the trips I make....I'd just like access to it out of curiosity more than anything else.
I think you may be misunderstanding hybrids. When I leave for work (4.2 miles) the first 2 miles out of my garage my ICE engine does not even turn on since battery power is on and it is a downhill/level for those first 2 miles. In down hill coasting areas the hybrid makes very significant regenerative power back into the battery. My to work route is 3.1 miles WITHOUT the ICE even turning on. ..1.1 more of those miles are uphill, red lights and level areas when the ICE comes on as the battery is being recharged. In the hybrid the dash green bar and engine sound tells you when the ICE turns on.Kind of a dumb point for me to make, but it occurs to me that there are zero miles driven electric in a Maverick hybrid, because it is not a PHEV. There are only miles driven by gasoline. Even battery mode is indirectly gasoline, since every electron used in a Maverick hybrid is originally derived from gasoline. That includes regenerative braking, if the Maverick hybrid has that (I hope it does).
OP, don't interpret this as me trolling you. Not my intent. I was just reflecting on the thread and that thought popped into my mind. A hybrid uses gasoline more efficiently, but in the end it's still all gasoline.
Much of the electricity from the hybrid battery comes from regenerative coasting or regenerative braking. That is energy that would not be captured in an ICE only vehicle, so it is "free" energy that would normally be lost as heat released to the atmosphere.Kind of a dumb point for me to make, but it occurs to me that there are zero miles driven electric in a Maverick hybrid, because it is not a PHEV. There are only miles driven by gasoline. Even battery mode is indirectly gasoline, since every electron used in a Maverick hybrid is originally derived from gasoline. That includes regenerative braking, if the Maverick hybrid has that (I hope it does).
