Maverick and Escape wheels / rims interchangeable?
Geep
Paul
SK Canada
2022 Ford Maverick XLT luxury hybrid
Are they the interchangeable? I have a set of winter tires/steel wheels for my Escape and wondering if they are transferablue……
GreatWhiteNorth
Daryl
Winnipeg
2022 XLT
Should work OK. These cheap steel wheels that I bought for snow tires are supposedly for an Escape. Bought them at a wheel specialty shop.
Ford Maverick Maverick and Escape wheels / rims interchangeable? 20211030_142944
Naranjita
NAH-RON-EE-TAH
Steamboat Island, Washington
Oooh! What do these look like with a straight on facing shot?
GreatWhiteNorth
Daryl
Winnipeg
2022 XLT
Do you mean straight on from the side? I think the snow tires on steelies looks fugly, but they work. We had freezing rain yesterday - bad. The roads were horrible, and had to go pick up the wife from work. Those Michelin X-ice are about as good as it gets in those conditions, helluva test. Nice to have the AWD, stability control and nanny electronics at times like that.
Ford Maverick Maverick and Escape wheels / rims interchangeable? 20211127_131634
Naranjita
NAH-RON-EE-TAH
THANKS for posting!
Wayne
Ontario
Hey guys will Escape rims work on the maverick? Everything looks the same other than the offset.
Canyon Racer
Jerry
North Texas
Technically speaking; yes Escape wheels fit. The Maverick has a ton of room towards the suspension which is the direction increased positive offset puts the wheel. If the goal is to put wider wheels and tires and stick out a lot more than stock then Escape wheels are not ideal. But, if the goal is to put larger wheels and tires and have a little more stick out than stock then some of the Escape wheels are a good fit.
Examples exclude wheel lip: 7.5" width wheel with 50 offset will be 12.5 mm more positive which puts the outside of the wheel in exactly the stock location and the extra 1/2" width all towards the suspension.
8" width wheel with 50 offset will be the same 12.5 mm more positive offset which puts the outside of the wheel 1/4" farther out and the inside 3/4" closer to suspension.
The Maverick has plenty of room for both of these examples. Most of the wider wheels for Escape are 18", 19" & 20".
Best place I have found to explore fitment is https://www.wheel-size.com/calc/
Hope this helps
FakeCowboy
Mid Atlantic
2016 Subaru WRX
Above post is great, essentially with the 17x7" et50 escape wheels they will be tucked in towards the truck a half inch so it might look a little odd. I'd try to find some wheels from the bronco sport, so many buyers seem to be swapping them out as soon as they buy their bronco sport so the market is flooded with them and they have the same exact specs as the Maverick wheels.
Administrator
Administrator
Staff member
MTC
Fords
Here is a post made by @GreatWhiteNorth. He purchased steel wheels spec'd for the Escape and fit it on his Maverick.
Source: https://www.mavericktruckclub.com/f...urce-for-factory-steel-wheels.3533/post-84223
I spoke with a parts guy at a different Ford dealership, and he offered that the Escape has same hub/wheel bolt pattern & 17 x 7. Lots of sources for aftermarket Escape steel wheels... and I bought a set of new aftermarket steelies locally, had snow tires mounted, just need to buy some lug nuts. Hope they fit - they should, offset, center bore etc. supposedly match.
I'm still amazed the parts guy at the first dealership (that I bought the truck from) told me he couldn't get steel wheels for it!
DThis is with Michelin X-Ice Latitude tires on Escape compatible aftermarket cheap steel wheels.
The Michelin X-ice snowtires on steelies are working out well, the Maverick performing well in the snow.
tamis
New York
Hope this helps
I'm getting a 22 XL AWD Iwant to put 18x9 38 offset TE37s on it, do you think I'll have any issues?
