Maverick accessories, mods, how-to's on my Maverick
wax87
Stuart
Dallas South
2004 Avalon
I will be adding a peel and stick mercury switch inside the tailgate no moving parts, no drill holes. Power on for 15 minutes after you shut the truck off, I also believe that when you unlock the truck it provides power there as well. 15 minutes is plenty of time to unload your groceries from the back.
but wouldn't you need a wire from the tailgate to the light? I could see a potential for that wife getting pinched. I guess you could run it with the back up camera wires.
Barracuda340
Barracuda340
Abilene Tx
The plan is to run it with the backup camera wires
Barracuda340
Barracuda340
Abilene Tx
Nice build. I like it, very neat and tidy. I also have a his and hers set of Mavericks. My cactus grey BAP just got delivered and my wife has a Black FX4. I've got my lowering springs on order, but I probably won't get it lowered until spring. I've got to ask, what brand of auto start/stop eliminator did you install? I've searched Amazon, but I'm only finding ones for the F-150 and the full sized Bronco(it states that it won't work on a Bronco Sport). I hate when I'm at a stop sign or short light and it shuts off.
It was a generic brand for a bronco sport. It works fine.
RivrMav
Ken
Missouri
2023 Maverick Lariat (Hybrid)
RCTEXAS18
Russell
2006 Silverado
Another cool thing I made to showcase my love of shooting sports, and cars were these valve stem covers. Aluminum shell casings cannot be reloaded. As such I usually leave em there since they are one time use. I decided to take a handful home from the range last time I went in for handgun practice.
How did you make those? That is very clever.
Barracuda340
Barracuda340
Abilene Tx
I used brass valve stem caps and machined them down just enough that a .40 caliber shell casing would fit. Then I set the casing over the machined cap with a small amount of epoxy and let them dry. I used aluminum casings. Once dry, I used an old 18 wheeler valve stem that I removed the rubber from. This i chuck up in my electric drill and spin while using finer and finer grits of sandpaper up to about 1800 wetsand. Then i hit them with metal polish on a paper towel.
Barracuda340
Barracuda340
Abilene Tx
My quick removable washable towel, I mean seat cover, I modified a bit. I added grommets on the side and bottom. Cut a piece of tubing to shove between the upper and lower seat cushions, and using some plastic tubing, parachute cord, and washers, i made ties for the side and bottom to keep it in place getting in and out. The washers hold the grommets at one end. The plastic tube you put thru the other end grommets to hold it. This way when i wash it, theres no cords to foul up the washing machine. Very simple. I had the grommet kit and the rest. Only needed to buy the towel and parachute cord. I am going to purchase a cheapo wintertime type woolen hat from amazon in grey to cover the headrest. For now I'm using my black Carhart one
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230414_190203
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230414_190209
Wizard
Russell
Kentucky
2023 cactus grey Maverick XLT
Thanks!! Trying to do step by step very descriptive and with pix so the novice DIY person can see how easy it is to do this.
You are doing a fantastic job of showing us how to do all this stuff, thank you so much.
Barracuda340
Barracuda340
Abilene Tx
I ordered these for the cup holders. I think they will be pretty cool. Will prob set them up as light blue to match the dash backlighting
Ford Maverick Maverick accessories, mods, how-to's on my Maverick Screenshot_20230416-115808_eBay
Barracuda340
Barracuda340
Abilene Tx
Thank you. I am quite particular about stuff. I also have door handle covers, but am on the fence about them now lol
Delzona
Tucson, AZ
Redline Tuning hood strut kit. $99 off Amazon I believe. Uses a 10mm socket and 13mm socket and 13mm wrench. 15 minute assembly time. You have to remove the bolt and clip nut off washer fluid bottle. Well worth having these. No prop rod in the way.
This was one of the first mods I did to my Maverick! Never liked prop rods!
Delzona
Tucson, AZ
Woke up at 4:30 this morning to go for my morning run and get ready for work. Windy and 38° eh not so bad. I get to work and feel the temps dropping. By 8am its 11°F and has a windchill of negative 3°F. At this time I was rethinking me saying i didnt need the XLT lux pak in west Texas when I ordered this thing, and it delaying my order. That heated steering wheel and a heated seat would have been pretty nice to have right about now lol. The good thing is this engine does warm up and start pushing out heat pretty quickly.
I’m so glad I got the heated seats and steer wheel option! Even here in Arizona, I’ve used them quite often. Of course I would have made it through the winter without them, but having it certainty made it much more comfortable!
Delzona
Tucson, AZ
And how much room do you think your really gonna get cutting away the wheel houses. Maybe 2 inches on either side? A whole 4 inches for all your effort. I mean there is still tires, shocks, and suspension under there. It's not empty space.
Could I do this type of mod? Yup I sure could. Am I gonna? Nope. The gains are minimal. This is just a 4 door car with a large trunk to me is all it is. See pix below. This is me reversing a rusted floor, and horribly hacked in pop rivets and silicone aluminum minitub job on a 69 barracuda. Pix show that I am capable of doing this sort of stuff. The difference in the pix, is I am putting the car back to original, and restoring the structural integrity that was designed into it by the OEM.
Holy crap that’s got to be the biggest pair of vice grips I’ve seen! 🤣🤣
Barracuda340
Barracuda340
Abilene Tx
My el cheapo seat cover install step by step. Less than 2 minutes to remove and install. The green plastic pieces have proven themselves. I'm going to make them out of solid aluminum rod stock and use a drill press for the holes.
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230417_160642
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230417_160725
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230417_160757
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230417_160850
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230417_172622
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230417_172533
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230417_172646
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230417_161236
Ford Maverick Maverick accessories, mods, how-to's on my Maverick 20230417_161424
23MAVLariatAWD
VA
RECEIVED '23 Hybrid Lariat Mav Oxford White BAP
Whats the part #? Cool stuff!
