Maverick 2.0 Stop/Start disable
GTX4401967
Geneva Florida
2023 maverick
I am wondering if anyone has tried this with a Ford Maverick. Mine is in production right now so I can't try it myself.
I know you can go to 4D Tech and other manufacturers and buy a stop/start eliminator so that the engine won't shut off every time you stop or use the on or off switch.
On an F150 you can take a trailer light receptacle plug (just cut one off an old wiring harness) and plug it into the trailer light receptacle in the back of the truck. A very easy try especially if you have an old wiring connector laying around in your garage. It makes the truck think it is pulling a trailer and disables the stop/start mechanism. You can pick one up for a couple bucks.
If someone has tried this or wants to give it a shot let us know if it works that would be great!
eighty4south
San Diego, CA
2024 Ford Maverick XLT, FX4, 4K Tow, Atlas Blue
Would using a trailer hitch cover light work? Something like this? (First one that came up on Amazon)
CZC AUTO Red Lens Trailer Hitch Cover with 12 LED Brake Light Fit 2" Receiver https://a.co/d/9zHKmlc
Golfsnob
St Augustine
2023 Maverick XLT AWD 2.0
Forscan. It's simple.
Golfsnob
St Augustine
You have to change the values in the "AS Built" in the PSCM module address 730-03-01. There are 3 sets of values. In the 3rd set of values change the 1st 2 digits from 01 (enabled) to 00 (disabled). Then click write all and follow the key off/on instructions. That's it.
paneubert
Seattle
Your cross traffic alert sensors will turn off if it thinks you are towing.
