Mabett side marker lights turn signals
Chris_G
NOVA
C-6 Corvette
RE: GadCad = I can't find that - it defaults to GrabCAD. However, I did not see a way to order any lenses on GrabCAD. Suggestions?
Any other ready-made source for lenses to cover the opening?
Wish: I wish Ford had designed the side emblem such that we could use the side marker assembly, drill a hole for the wires and snap or glue it in. Ford, are you listening? I made a template of the side marker to see if the profile would fit into the recess in the side emblem but it was not the same, close though.
GadCad3d
Toddman45
St. Louis, MO
They look good, but to many issues with water intrusion for me.
Chris_G
NOVA
C-6 Corvette
GadCad3D = That helped - I see the product. Thank you so much!
My pleasure!
Think I will use double sided tape on the top and sides. leave the bottom open so condensation doesn't collect.
Chris_G
NOVA
C-6 Corvette
Oscarcat
Eric
Encinitas California
My pleasure!
RE: Amber lenses - I now have mine on order - $24.99 USD. Do you think 3M double-sided tape will show through the lens?
Although I do no get as much rain as you, the thought of condensation occured to me. I can't decide if leaving the bottom unsealed will provide a weep hole and allow the interior to air out or if it is an invitation to trouble. Meanwhile, being so close to engine heat, I wonder if a small hole or even two, in the emblem, say above the hole where the LED is, would be a better option and take advantage of engine heat?
Are you planning to wire/install so it illuminates like the side marker light and also flashes with the turn indicator as well or just as a turn indicator? I plan to use the Mabett video as my wiring guide. Cheers.
Mdmac
Kansas
2023 Maverick XLT
Hello Oscarcat, I just installed a set on my 2023 XLT and if you're a little mechanical it is a pretty easy install. As far as condensation I noticed some on the passenger side of mine. Not sure what to do about it..
Chris_G
NOVA
C-6 Corvette
Yes, that's exactly how I have them wired. Connect by wire location, not color.
Chris_G
NOVA
C-6 Corvette
Return them!
Mr Pibb
Vegas
2024 Lariat
Anyone dismantle one of these to get an idea on where the leaks coming from? Best guess right now is the clear part is just a lens popped on and whatever gasket is there just isn't seated properly. Maybe pop it off and add a lil rtv and reseat it.
Mdmac
Kansas
2023 Maverick XLT
Just got mine installed and did notice some condensation on the passenger side light?? Need to look into it
Oscarcat
Eric
Yes, thankfully I am mechanical enough to install. However, I am a bit hesitant to wire into what appears to already be a delicate and quirky electrical system.
You used the Mabett kit, right? I am going for an OEM look. So I ordered amber lenses that fit the profile of the logo piece. I just need a recommendation on an LED bulb that I can mount in a rubber grommet in a hole I will drill from the outside - meaning the logo piece remains in place and I can poke the wires through the grommet/hole.
Even though I like the animated lights. I feel that Mabett does not have their act together yet. Cheap pricing poor quality won't cut it for me.
I feel, having either fender or mirror mounted signal markers, is a nice safety feature. I've them as oem on a few of my vehicles. More than likely I will go with the ones pictured below. I have seen video's of these.
They will do the job as intended.
I wish they made them as switchbacks. 👍
Ford Maverick Mabett side marker lights turn signals Screenshot_2024-06-07-08-29-44-65_40deb401b9ffe8e1df2f1cc5ba480b12
Not as fancy. Stay safe.
GB
Conservatively Flashly.
