Mabett side marker lights issues.
javelar
Javier
NC
After install per instructions, one light stays on even with ignition and lights off. Anyone else have this problem if so whats the fix. Really like the product and want too keep but if defective will return.
javelar
Javier
NC
Update: enclosed instructions were not correct, had conntetion to hot side not switched side. When wire was connected correctly, light worked as expected.
dc73pdsgt
Tucson, AZ
2023 Ford Maverick Lariat Hybrid
so you answered your own question then?
Maverick2023
Kip
Atlanta, GA
Toyota Rav4
I scrapped the instructions as soon as I saw it wanted me to tap into the headlights. You can tap into the parking light at the bottom instead
javelar
Javier
NC
Yes, answered my question. Now need to find better connectors. Don't like the ones that came with the kit. Any suggestions?
IHateSpeedbumps
Nick
Central Texas
I am planning on using posi taps when I do mine. They seem like the best bet if you don't want to do open barrel splice crimps.
BMK
Bruce
Ohio
2024 Maverick Hybrid XLT
I had the same problem. Once I cut the passenger side Red wire to the Headlight, it no longer stayed on with the car off.
It functions correctly as does the driver's side.
I tinted mine dark grey to keep the BAP intact. The LEDs shine through it easily.
Ford Maverick Mabett side marker lights issues. 20240503_173505~2
Ford Maverick Mabett side marker lights issues. 20240503_173503~2
deezionu1
Dee
2024 Ford Maverick Hybrid
Hello, after I hand washed my 2024 Maverick Hybrid I was drying it when I noticed condensation in the passenger side light. Any fixes out there. Thanks in advance. Dee
Ford Maverick Mabett side marker lights issues. IMG_0724
Ford Maverick Mabett side marker lights issues. IMG_0723
Chris_G
NOVA
C-6 Corvette
Members have been adding fish. Makes good use of the water and looks waaaay cool.
Palms
Gus
Jensen Beach, FL
21 Mercedes GLC; 23 Maverick Hybrid Lariat
How did you connect the red passenger wire to which passenger side headlamp it so it works? My instructions only covered the 18 steps to complete the driver side, Thank you.
