Lower / Under Tailgate Light Bar
Dave O
New Smyrna Beach Florida
Anyone install a tailgate light bar (running lights, brake light, turn signals, hazard lights, reverse light) what brand did you install and did you only use the 4-Pin connector under the rear bumper or did you have to install a special wiring harness to avoid having a conflict with the trailer recognition software?
Dr. Ron
Ron
Mission Viejo, CA
2023 Lariat
I just installed one and initially used the 4-pin connector but discovered that disconnected the rear back up camera so I had some one install it with a special wiring harness. It now works very well. I am sorry I cannot remember the name but I ordered it off Amazon and be sure you get the shorter one which will also be narrower allowing the light bar to avoid blocking the spare tire access hole.
WavnAtCha
Howie
Wesley Chapel, FL
2025 Ford Maverick Lariat
Have you checked your Amazon purchase list to get a URL for this special harness?
OleFordGuy
check the "similar threads" section at the bottom of the screen.
Mdmac
Kansas
2023 Maverick XLT
Hello, I installed one on my 2023 XLT. Actually I had Uhaul install a Receiver Hitch so I could pull a trailer. I will have to look into mine I got from Amazon. And I bought a wire with a 4 pin connector on both ends and just plugged it into the wiring from the hitch. So far I've I had zero issues and it has all the functions that you mentioned. I like it especially at night because it just adds a little more visibility in the dark. Good luck how ever you end up doing it
