Lower Octane Fuel
GPSMan
Many
FYI 13:1 compression requires about 110 octane.
There's your hint right there something is different about the Hybrid engine.
Enjoy your truck, on any regular pump gas.
Ford Maverick Lower Octane Fuel 1699051391198
A little more corroboration:
Ford Maverick Lower Octane Fuel IMG_8545
BlueRaven
Iowa
24 Mav, 01 CRV
i have over 17000 miles on my 22 eb. 90% of the time i use e15/88 octane. i get 25-32 mpg depending on my trips and driving. i used e91 when i towed my small camper from iowa to colrado and back. zero issues with either choices. my only 2 pennies. whatever you do, NEVER buy fuel at love's. its junk. also be consistent. to me the $1 per gallon difference is not worth it for a dd.
GPSMan
Many
dd= daily driver?
Raymundo76
Ray
Mesa Az
21 Mazda CX-5
So 87 0ctane works for a compression of about 8.7, if this is correct 91 is appropriate for the hybrid, no?
GPSMan
Many
Well, two things:
1) we don't know the actual compression ratio
2) most octane charts I can find are from 1970's and 80's with carburetors and no electric controls.
Just like a 2.0 liter today outperforms a 6 liter engine from 1970, so do engines today on lower octane.
Octane is a rating based on the behavior of the fuel. But, as the years went along, the behavior of engines changed with more sophisticated controls.
Just like a gallon takes you farther today, lower octane works in a wider range of vehicles today.
Raymundo76
Ray
Mesa Az
21 Mazda CX-5
Well, two things:
Ford knows and they recommend 91. that is good enough for me. Others not so much. This is likely my very last vehicle, so I am going to use 91. It is another example of the "law of unequal consequences". If I am wrong I spent 10%+- too much on fuel; If the 87ers are wrong there may be engine issues. Since I can afford the extra cost of 91, I will use the higher octane. If one wants to use 87 because Ford says it is OK, that is their choice. I have said all I care to say on this issue. Have a great day and enjoy your Mav's.
TC in MN
Minnesota
2022 Ford Mav XLT, CG, 2.0, AWD, Lux, tow, 360
Somewhere I read when direct injection engines are in turbo mode they recycle what was not used up in the combustion cycle back into the air intake and straight to the intercooler. Because of this, the argument for using higher octane is one gets a cleaner burn. Without researching this, it made sense to me.
This is where the oil catch can issue raises its contentious head. Having a oil catch can, my experience is unless the engine is working hard, the 2.0 eco runs very clean (no waste in the can). Ultimately IMO the reason for the higher octane usage is the intercooler getting less gunk in it when in turbo mode and wishfully hoping it helps with carbon build up on the valves.
dalola
Retired
SE Ohio 🇺🇸
I now have a little over 2100 miles on my Maverick. Up till now I have only used premium fuel. I drive conservatively, can I safely use a lower grade fuel. 2.0 Turbo
To answer *your question directly & specifically* minus the 8 pages of debate: YES!
For all the nuances, just review the 8 pages (not done yet!) of debate. 🤠
GPSMan
Many
PLUS HYBRID AND ECOBOOSTS ARE TWO VERY DIFFERENT ANIMALS.
WHY PEOPLE LUMP THEM TOGETHER IS A MYSTERY.
