Leveling with springs or struts?
rocarbs
Roland
Puerto Rico
2023 Ford Maverick XLT Hybrid
I want to level the front of my 2023 hybrid xlt and I'm looking at the Eibach MAVERICK HYBRID FRONT LEVELING SPRINGS, anyone have had these installed? Was also reading that front can be leveled changing the struts, has anyone gone this route? Pros cons?
FERALMAVERICK
Brent
2025 maverick tremor
if your just wanting to level it . i would go with a spacer kit , like zone , rough county , hrg . easy install , cheaper no additional parts and gives a solid level ( just get and alinement afterward) vs taking apart the strut assy. and replacing all 4 springs and needing camber bolts ( still needs and alinement ) i went with a zone level kit on my own truck and it did exactly what i was looking for the install took a little over and hour with had tools ( wasn't rushing ) i was originally contemplating springs vs a spacer also
Ford Maverick Leveling with springs or struts? 20260310_091041
Ford Maverick Leveling with springs or struts? 20260310_102856
Ford Maverick Leveling with springs or struts? 20260319_114303
Master Blaster
Master
Toronto
23 Maverick Lariat Hybrid
C/V joint failures. Don't do it. Nobody has a kit that keeps the joint angles from changing. That requires the transmission to drop with a new subframe cage.
Paulyz
Paul
Forestville, WI
Let us know if you experience any cv joint problems. I'd like to try this.
