Noise with 1" leveling kit
Haha48
Scott
Canada bc
Put a strut.in backwards. Didn't bolt it down. Did you do a wheel alignment?
M Spec
M Spec
South Carolina
1978 Toyo LC, 1988 911, 2005 STI, 2010 STI, 3 More
I mean no offense but have you ever installed struts on a Maverick?
Haha48
Scott
Canada bc
People have screwed up before you would.be surprised. If it was backwards it would angle out sideways. Sometimes they just forget the third bolt under the plastic
Pudakis
Pittsburgh
Did you ever find the issue? I don’t have the leveling kit and mine also makes a clunking noise, I had it at the dealer today for that and the trailer brake recall. They told me there is a known issue with a bolt, I didn’t get my paperwork yet as they will mail it to me. But they fixed the bolt and Things feel way better and a had a slight vibration that is gone but I believe I still have the clunk.
tomahawk72
Travis
Westbrook, Maine
22 Maverick XLT
Thanks...I mean no offense, but I have been building cars for over 50 years and have owned over 70 cars/trucks, I do how to tighten bolts. But again I do appreciate you taking the time to post.
Even the most experienced technicians can still make mistakes. Instead of being ignorant have you tried double checking everything?
WeatherDJ
Eugene
Connecticut
Acura MDX
I would appreciate posts from individuals that have actually installed the leveling kit, Thanks
I installed the 1" RC level kit myself. I bought the kit early on before I received the truck and it was the steel kit, looks like they are now using molded plastic? The kit bolts were too long and I had to source new bolts to mount the spacer to the strut. Anyhow, I have a clunk in the right front over harsh bumps. The clunk started about five months (3K miles) after install. Sounds like a bad strut or strut bushing. When the weather warms up here in the NE I'll take it apart and check the spacer. I checked all the other bolts which I could access without removing the strut and they are all tight. I have an upcoming appointment at the dealer for the airbag recall. I may ask them to take a look. Well see what they say about the level kit and larger tires (245/65). :)
