- First Name
- Brian
- Sep 20, 2022
- Fredericksburg, VA
- 2018 Honda CRV
- Engine
- 2.5L Hybrid
I have a 23 Hybrid with 2200 miles on it. I went to turn on the light in the bed and got nothing. I never did test the two power outlets when I picked up the truck, but the light did worked previously. I did start the truck to try the outlets. The light should work without starting. I assume these are using the same fuse. I could probably figure out which one to check, but I want the dealer to address it so that it is documented. I called the dealer and asked if they could check the fuse real quick see if that was the issue. Nope, you need to drop it off (next appointment available is 10/17). Since I need to drop it off, I am having them look at the center speaker grill as it does not fit flush and I have to stare at it every time I drive. I was going to let the speaker issue sit until I had a significant warranty issue, so I guess this is it. BTW, this is not the best users manual I have had, but better then the instructions I get from anything made in China.
