Lasfit replacements
SWFLGulf
Naples FL
On Monday the 11th, I received the replacement T3 bulbs for my Maverick XL. I had requested them last month to solve the hyper flash issue after the turn signal update.
I installed them and they work great. No more hyper flash. I had also informed Lasfit about a failed brake/ turn bulb on my wife's vehicle. They told me that it was covered under warranty and included 2 replacement bulbs in my T3 shipment. No charge.
I am very impressed with their customer service. If you are waiting for the T3 brake/turn bulbs for your Maverick, they are back in stock. If you requested them, they should be showing up if they haven't already!
paneubert
Seattle
I also requested and received the new T3 bulbs for my Maverick XL. I have not had the recall performed, so I can't provide them feedback on if it "fixed it", but it is good to hear from a fellow XL owner that it does seem to correct the issue. Now I have less of an excuse to delay scheduling the recall fix.....
Gvmumbral
Gerardo
Pasadena, CA
Honda Element
Replaced mine with the T3 free of charge as well. But they do hyperflash. On the dash at least. They hyperflash for a few click when you first use each turn signal or hazards. Then back to normal.
SWFLGulf
SWFLGulf
Naples FL
I haven't experienced that since I installed them. But I will keep an eye for it.
I forgot to mention that I also installed new front signal bulbs. I went with the amber LED and not the switchback as others have. They are bright which is what I want down here in FL where during the day some vehicles turn signals are hard to see. If they are even being used! LOL
SWFLGulf
SWFLGulf
Naples FL
I delayed the recall also due to issues booking an appointment and having the vehicle sit for 2.5 days and not even looked at after waiting approx 3 weeks for the appointment. That was for the PCM reprogramming recall. I picked it up without it being done.
Then the dealership started the Mobile Service program. I called on a Monday and got an appointment for Wednesday. The tech showed up earlier than expected, got right to it and handled the PCM and the turn signal recalls within 45 mins. He also checked all the fluids, topped off the washer fluid and checked PSI on all tires.
If your dealership offers that service, use it.
numike
mike
car
they all burned out on me
