Key = Good & Push to start = Bad
Mr Pibb
Vegas
2024 Lariat
You have a poor outlook on life.
And I'm talking about the ignition.
Maybe go back and read all the posts you skipped over. If you care
You literally just mention everything but the ignition. I know its hard to keep up with yourself sometimes when every article has you scared that you'll be the victim of the next kia boys.
Mikestill1
Mass
2025 , xlt, hybrid awd
Key , no keys, faraday pouches. Like most have said, they will take your vehicle of they want it..
However have you seen a new method... accessing and reprogramming through the vehicle canbus... cool tech, but bad for vehicle security.
The Real Maverick
The Real Maverick
Jack
Yes.
Newer / fancier vehicles have canbus (and now there is a next generation communication protocol) running all over the place. While you and I have a dedicated spot to tap into it under the dash by the driver's left knee, skilled persons can tap into it anywhere. Some have gone behind the headlamps!
Headbanger
Ron
Finleyville PA
2023 Maverick Hybrid Lariat
The solution can be a hidden physical kill switch you use when parked, a physical club on the steering wheel, or a mechanical lock.
The guy with lock picking skills won't have a fancy computer jammer, and the guy with computer jammer won't have lock picking skills.
Probably.
Usually.
I was going to mention a physical kill switch. I remember back in the 80's that was a big thing with the muscle car owners. That and battery disconnect knobs.
JasonDroninAround
Jason
Hanford, CA, USA
www.youtube.com
2025 Ford Maverick Tremor
Those might work as an ANTENNA rather than as a faraday cage, increasing the effective range rather than limiting it - so do test whatever solution you come up with.
Yes I've been doing some reading since then, they say if you use any type of metal box, to make sure the keys are isolated from touching the metal. I just got home from a Eastern Sierras to Death Valley camping trip and I'm going to try it out now.
Ford Maverick Key = Good & Push to start = Bad 20250424_185500-EDIT
