Status
Not open for further replies.
JJC
Justin
KC
AWD EcoBoost
Maverickman74
Shane
Maui HI
Thats baddass! I will take mine with some adjustable height suspension. A bronco badlands sway bar, a turbo, tune, and intercooler.
JJC
Justin
KC
AWD EcoBoost
  • Thread starter
  • Banned
  • #4
ISC Suspension should have adjustable coilovers available this Spring, I was just impatient and went with the H&R Escape springs for the time being. I'm definitely happy with them for now but adjustable coil overs are at the top of my list once they're available.
Maverickman74
Shane
Maui HI
I was thinking actively adjustable ride height type. I live on real rough roads and fully flex out most stock suspensions on my driveway. It would be awesome to have nice stiff stance like yours on the street and then pump it up when the going gets rough. Im always trying to have my cake and eat it too. I want to build my 80 Eagle the same way. Hotrod muscle wagon burnout machine/ go anywhere 4x4.
Maverickman74
Shane
Maui HI
Adospeed
Ado
Colorado
Hybrid in Shadow Black
Oh Really @JJC ? I have their coilovers on my LS460L. I can tuck the tires with those coilovers.
  • Like
Reactions: JJC
JJC
Justin
KC
AWD EcoBoost
  • Thread starter
  • Banned
  • #8
Yeah, spring was the latest ETA when I inquired about it on IG.
For those unfamiliar, ISC made the coilovers for Tucci Hot Rod's Maverick that was at SEMA.
Ford Maverick JJC's Iconic Silver build IMG_7195
volksnuts
Katy,TX
Maverick Lariat HPR
Any side shots of the drop? Have the springs settled yet?
JJC
Justin
KC
AWD EcoBoost
I was planning on getting some pics all around and starting a build thread once I got the exterior finished up, but the admin beat me to it by making this thread lol.
I'll get some updated pictures this week and measure again to see if the drop has changed any from settling.
Mrdon2022maverick
Don
Georgia, USA
2022 Ford Maverick Lariat
YOU HAVE SOME SKILLS....BRAVE CUTTING INTO THE HOOD. I'M A NOVIST AND WON'T ATTEMPT THAT.... BUT THAT'S JUST ME. YOU GUYS ARE VERY TALENTED!!
JJC
Justin
KC
AWD EcoBoost
I recently made my own hard, one-piece bed cover. I got the anodized angles cut to length from 80/20 and three 18x55 ACM panels from Falken Designs on Amazon. Nice and low profile like I wanted. I'm about $250 all in and this thing's solid, probably a little too stout for what it is really. Anyways, I couldn't justify $1200+ for something that accomplishes nearly the same thing. I've also read about plenty of the high dollar covers that are coming up short. This one gives me just enough overlap for a great seal all around. Also, I think I rolled up the bedcover on my last truck about a dozen times in two years. If I needed full access more often I certainly would have considered a different option.
This cover doesn't do any tricks, it's either on or off; but it also doesn't flap like Batman's cape on the highway. Not sure of the total weight, I'd estimate ~60-70 lbs maybe? I can remove it by myself if needed but it's easier with a second pair of hands.
I'm thinking of adding two t-slotted profiles on each side so I can mount things to it as needed, such as cross bars or for an attachment point in setting up a roof top tent on the cover.
Ford Maverick JJC's Iconic Silver build IMG_6877
Ford Maverick JJC's Iconic Silver build IMG_6881
Ford Maverick JJC's Iconic Silver build IMG_6882
The ACM panels gave it a really low profile of about 1/8", I added some edge trim that I had left over but that bulked it up a bit so it sits about 1/4" above now. I'm thinking I'll remove the edge trim and just polish/bevel the edges of the ACM.
JJC
Justin
KC
AWD EcoBoost
Making the hood vent pics & info. a separate post so I can update the OP to be a current gallery and link to various mods:
Ford Maverick JJC's Iconic Silver build IMG_7185
Ford Maverick JJC's Iconic Silver build IMG_7186
I spent significantly more time placing my template than actually cutting.
Measure a thousand times, cut once 😅
Ford Maverick JJC's Iconic Silver build IMG_7175
Ford Maverick JJC's Iconic Silver build IMG_7177
Ford Maverick JJC's Iconic Silver build IMG_7178
Ford Maverick JJC's Iconic Silver build IMG_7181
Cut was perfect, the vent snaps in just like it's designed to on the Camaro. I'll be touching up the cut edges and repainting all of the exposed edges.
Ford Maverick JJC's Iconic Silver build IMG_7182
Need to do some trimming to this water tray to get it fully bolted on such that it seats against the hood properly. Per my placement of the vent, this should drop any water right in front of the engine but just behind the air inlet tubing that's behind the radiator. Likely a non-issue in my case though as this isn't a daily driver and is garaged. Just have to take a little more care when washing.
Ford Maverick JJC's Iconic Silver build IMG_7187
Ford Maverick JJC's Iconic Silver build IMG_7190
Status
