Is this normal or is something missing?
BigE434
Wayne
Clarksville, VA
2023 Maverick XLT
Does your Maverick have a cover here or an opening like mine. It looks like a removable panel should be here.
Ford Maverick Is this normal or is something missing? 20231019_151121
Ford Maverick Is this normal or is something missing? 20231019_144129
psuarmy
Pittsburgh
22 Maverick
FX4 has a little plastic air diverter for cooling. The PTU I believe. Also makes oil changes easy.
801Maverick801
Utah
Subaru Forester
You should have a plastic scoop there that directs air to your PTU to cool it. I would get it installed.
Oscarcat
Eric
Encinitas California
I believe the cover or scoop as someone called it was the subject of a service bulletin [TSB] concerning fires? I noticed my splash cover had no cover/scoop in the opening after taking it the stealership for the first oil change - they removed it. If you haven't had a dealer change your oil, then they must have started removing it in production.
Superdog3657
Ohio
2011 ford Ranger Xlt waiting for xlt maverick hybr
I noticed that opening when I did my 1st oil change,so my splash guard came from the factory that way.
huunvubu
coppell tx
2023 Ford Maverick Hybrid
BigE434
Wayne
Clarksville, VA
2023 Maverick XLT
I should mention that my Maverick is a turbo not Hybrid.
If I’m looking at the correct spot, my AWD has a plastic piece inserted there. Mine was delivered right after the recall with the new shield, so it didn’t have the recall
Ford Maverick Is this normal or is something missing? IMG_6464
BigE434
Wayne
Clarksville, VA
2023 Maverick XLT
That is the exact spot. Thank you. That is the plastic part mine is missing
Your welcome! Maybe someone on the forum knows or can find a part number for ya. Good luck
BigE434
Wayne
Clarksville, VA
2023 Maverick XLT
Does anyone know the part number to order this?
MavTime
23 Maverick Hybrid XLT
My XLT Hybrid was delivered at end of August and I don't think it has been to the dealer for service or updates (previous owner had it for a month) and I have the same large hole with no cover, no drilled holes for any fire recall. Does the app tell you if you need a recall, mine doesn't show anything yet?
BigE434
Wayne
Clarksville, VA
2023 Maverick XLT
