Is this bed cover installed correctly?
Gray Goose
RG
Wissota
Maverick XL 2024, Escape 2012, GMC Terrain 2017
We would think that Ford engineers could get measurements correct.
It is just like the rear axle Not being in the center of the wheelwell.
It's like a teenager. The body grew faster than the wheelbase. When it gets all grown up, it will even out. 😂
JDMaverick
North Texas
Maverick Lariat
I bought some weather stripping and filled any gaps around the tailgate. A little water gets in but is mostly dry in there.
Diverguy64
Nova Scotia
2023 Ford Maverick
Our 23 XL has a factory installed cover and it sits further back on the tailgate than the one in your photo. And I recently installed a cover myself on our 22 XTL. The brackets on the side rails allow some movement front or backwards during installation, so it can be positioned just right. As long as the front edge sits over the seal on the bulkhead, you can loosen and slide it all backward an inch or so.
Toddman45
Todd
St. Louis, MO
Yes it is, obviously the cover should extend over the edge of the tailgate. But I didn't buy mine from the dealer, nor would I want them to install it.
I went with the Rough Country trifold, it extends 5/8" over the tailgate. I'd be upset the cover doesn't even extend over the rails or the side of the bed.
Ford Maverick Is this bed cover installed correctly? 17399188225945093144151429286230
Ford Maverick Is this bed cover installed correctly? 17399193510217279675599397111033
RideSolo
Cory
North Central Ohio
'24 Lariat Hybrid, Shadow Black/'20 Escape Titanium Hybrid/'75 BMW R90/6
I know this isn't a very good or clear picture but I was just outside w/ the dog and decided to check the tailgate overlap on my tonneau. This is the Ford tri-fold and I don't know if it came from the factory or if it was dealer installed. However if you can figure out my crappy picture you'll see that there's around an inch overlap on the tailgate. I wouldn't be surprised if you loosen the clamps on yours and slide it toward the back until it's more centered, front to rear, you'll be happier w/ it.
Ford Maverick Is this bed cover installed correctly? Maverick012
umpkey
Bunnell, FL
I have the same cover and same issues. Went on line, and checked out the cure for this, and it works very well. Amazon had a 3M gasket and videos on how to apply. No dust and only minimal water issues after installation. Check it out.
Mike,
Can you provide a link to the gasket kit you bought. I have been looking to get my BAK hard folding a little more leak protection knowing it will never be 100%.
Thanks
MikeS1942
Windsor Ontario
24 Maverick Lariat
Mike,
Thanks
Just go online and search Maverick tailgate seal kit. There are videos showing how to install. It's pretty easy. It's not 100%, but it is a large improvement.
