Is it possible to remove securipass keypad on XLT?
bioned
New York
I know securicode comes default in XLT/Lariat, default as in drilled to the door.
Is it possible to remove it?
the idea of a 5 digit code tingles my GTA paranoia
unclerunkle
Aaron
Wisconsin
Grand Marquis
Doesn’t answer your question but I love that keypad. Leave my keys in the car all the time without hesitation. I live in a pretty low crime area so ymmv.
Maybe give it a shot first? Otherwise there may be a fleet delete option I’m not aware of
jsus
2022 Ford Escape Hybrid AWD
Don't really see why not. It's just plugged in. Should be able to pop off the trim on the pillar, remove the keypad, unplug it, and just cover it up with a blank trim piece (could probably just swap on one from an XL).
Worst case scenario, it would throw an error code somewhere but it's not going to otherwise impede operation of the vehicle.
The branding is actually SecuriCode.
Ford Maverick Is it possible to remove securipass keypad on XLT? 1673752565973
bioned
New York
I mean before scheduling. Can the dealer remove it?
jsus
Maybe with a Fleet ID #... It's standard equipment. Comes whether you want it or not.
Only way to remove it is to physically remove it after purchasing the vehicle.
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Considering the number of possible combinations, and that it locks out for a set amount of time every 5-6 attempts, it would take a long time for someone to figure out the combination. Somone could pick the wafer door lock faster than the keypad, unless they are very lucky.
jsus
Someone simply looking to steal something from the vehicle would usually just break a window and be gone before you know it anyway. Standing there entering code after code is more likely to draw suspicion if it's a quick smash and grab.
The keypad just lets you open the door, you still need the key to start it.
Seems there are better things to worry about as I'm not aware of any large scale attacks on SecuriCode, and Ford's been using it since 1980.
